Thread: Hayward S240 - Low Level Sand
    Jul 2009
    Eden Prairie, MN
    37
    Hi. Just opened the Hayward S240 filter and took this photo. I am replacing the sand and only found the S244T Hayward manual online which says 300 lb of sand for the S244T.
    Is the S244T model sand capacity the same as the older S240? If so, then I should buy 300 lb of sand?
    Does the sand level look low in this photo?
    Thanks.
    AGP partially buried, with surrounding deck and flower bed. 12 x 24 oval x 48" deep Celebration by Forum. Steel sides, vinyl liner. Hayward 2 HP sand pump. Flower fountain - works well to cool water up to 10 degrees.
    Re: Hayward S240 - Low Level Sand
    Yes, the S240 takes 300 lbs of sand.
    The sand looks significantly too low in your photos.
    Jul 2009
    Eden Prairie, MN
    37
    Thanks a lot!
