Thread: Power Control Board problem
    I have an Aqualink RS system installed in 2004. We recently opened our pool and several problems with the indoor pool controls were noted. A factor that may be responsible is the fact that I probably left the door of the control panel open for part of the winter here in Maryland.
    In fact, a problem was first note during the winter when I turned the control panel to Auto so that I could place the pool pump on a timer. I noted that the Spa light came on when Freeze Protect kicked in, even though the light was not set up to come on.
    When the system was hooked up a few days ago, we were unable to get the Spa heat to come on from the indoor panel – we could not get the Remote button on the heater to work. When the heat was enabled from the indoor panel, the light on the panel that turns red when the heater comes on will blink green-red-green-red, etc. The Pool heat is operable from indoors, however. Also, when the Spa is turned on from the inside panel, it can only be turned off by using the control buttons outside next to the spa. Using the indoor panel does not work.
    The unit seems fully operable from the main outdoor control panel. Given the above information, do you have any thoughts about what is malfunctioning? Thank you very much!
    Dave
    30' Vogue Zenith AGP (21,000 gallons)
    Hayward Power-Flo Matrix 1.5 HP Pump
    Hayward XStream CC1500 Cartridge Filter (120 GPM)
    Re: Power Control Board problem
    wow! i have same problem too with jandy...
    do any of thse work correctly? seemslike junk to me
    do you think a cold winter can affect the outsdie power box and its chips??
    here in NY we had a brutal winter!
    I had a service call, and it looks like it might actually be the Spa-side control that is having a mind of it's own. That is a lot less pain in the wallet!
    Dave
