Thread: Foam for under the pool
    Do I want to get something like this..http://www.homedepot.com/h_d1/N-5yc1v/R ... ogId=10053 How thick should it be? Thanks!
    Intex 15X48 metal frame pool
    Re: Foam for under the pool
    Something more flexible is preferred. Rigid foam will end up uneven unless the surface you are putting it on is very flat. One inch is fine.
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    I have used 1", 1 1/2" and 2". I think the 2" worked the best. It was sturdy enough to tape together and lay flat. 1 1/2 seemed to break just to easy when setting up the pool. 1" just fell apart and cracked while under the pool.
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
    JasonLion,
    Can you give me a name or link to the type of foam I need? Thanks!!
    There are a lot of different ways to go. Gorilla Pad is one of the better ones.
