Results 1 to 7 of 7
Thread: Paver recommendation needed
    Apr 2011
    Collegeville, PA
    23
    Hi
    Does anyone know of a brand of pavers that has one that resembles beige tone travertine? We live in PA and I don't think real travertine will wear well over the years b/c of the freeze and thaw issue...I don't really want poured concrete or aggregate b/c it will eventually crack. Any other suggestions?
    Thanks!
    Kristina
    32,000 gallon, inground gunite, Blue Granite pebblesheen with luminous and shimmering sea shells
    Re: Paver recommendation needed
    You are not going to find any man made paver that even comes close to travertine.
    I tried.
    24k gallon inground with 500 gallon spa, 580sqft Jandy cartridge filter, Jandy ePump 2HP variable speed pump, Jandy 1400 SWG AquaCal Heat Pump, Diamondbrite Aqua Quartz plaster
    Apr 2011
    Collegeville, PA
    23
    so what did you end up going with?? I am actually reconsidering PA Bluestone but am afraid it will be too hot on bare feet...
    Apr 2011
    Maryland
    18
    I live in Maryland and last fall put down 1600 sg ft of travertine pavers and had no problems over the winter.
    18000 gal Gunite free form
    Jandy 1 HP pump
    Jandy DEV 48 filter
    Raypak 400 heater
    Goldline Proligic SWCG
    Solaxx chemical feeder
    Dolphin Deluxe 4
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    This is what I'm doing with my deck all around the pool. I'm placing buff sandstone in the middle. I've got concrete deck around the pool, but I wanted the buff sandstone in the area I'm doing my own deck so people can walk on it when it's hot...
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    Search for "peacock pavers" or "traverstone"
    Size 12,000 gal | Filtration Jandy 340 CL Cartridge | Sanitation Jandy 1400 AquaPure SWG | Placement In-ground Gunite | Finish Medium Gray Plaster | Automation Jandy Aqualink RS w/PDA6
    Pump Jandy 2.5hp 2 speed Stealth | Location New Orleans LA
    Heat Jandy EE2000t
    Test kit Taylor K-2006 (fas-dpd)
    Tremrone Stonehurst Pavers in the color Sandstone.
