Thread: Question about Pentairs Quad De filters.
    I have the smallest Quad DE 60 and its been a great filter for the most part, but I noticed the larger 2 available units are rated for a higher flow.
    It seems to me but Id like to know for sure that I can simply buy a new DE- 120 and replace the cartridges into my plumbed in base and pop the larger top piece on.
    Seems that the top piece and filters are where the difference is and that bases are identical.
    Goal here is an overall lower operating pressure and longer time between cleanings and recharges.
    I would then sell my units as a used (but 1/3rd) new pentair quad DE filter.
    Workable? Thanks guys.
    Uncle Dave
    20K Gallon Gunnite pool/900 Gallon in ground Spa/2HP WhisperflowSpa
    Pentair Master temp 400/Hayward Sand WZeobrite/Jandy RS-8 Aqualink/Jandy 2HP Epump
    12 - 4x10 Panels/Zodiac G3-T5 / BBB
    Re: Question about Pentairs Quad De filters.
    Page 21 of the manual shows a parts breakdown. It shows that you will need the following pieces to convert to the Quad 100.
    178582 LID, QUAD 100
    178583 AIR BLEEDER ASSY., QUAD 100
    178656 CARTRIDGE, QUAD 100
    195983 BACKWASH ASSY. - QUAD DE 100
    http://www.pentairpool.com/pdfs/QuadDEFilterIG.pdf
    http://www.pentairpool.com/pdfs/quaddeDS.pdf
    If you get a completely new filter, I would try to use it without taking it apart unless replumbing is a particularly difficult project.
    Support the site
    Plumbing looks like I unscrew the inlet and outlet and move the new filter into place-but anytime Ive ever messed with plumbing it always bites me.
    Perhaps Im being too cautious.
    UD
    you are correct, you would need the cartridge, air bleed assembly, and the lid.
    The backwash assembly is no longer needed, although if its an older filter, I WOULD recommend getting the 196024S as it aids in stirring up the DE on the bottom of the tank.
    In-ground Filters Engineer
    Pentair Water Pool and Spa, Inc.
    www.pentairpool.com
    1620 Hawkins Ave
    Sanford, NC 27330
