Thread: Inherited Pool, Pits and valleys in the liner bottom.
    Guest
    Hello all. Short version is bought a house that came with a swamp. Thanks to pool school, the BBB and you great folks, my water is crystal clear but I am still vaccing debris off the bottom, thwere was a TON of it and I have probably cleaned my cart filter at least 40-50 times to get this far. Shock is still going due to debris. When I was vaccing today I noticed that there were spots of debris that didn't go away want I passed the vac over them. I got my brush and stuck the last set of bristles in the spots and noticed that it droped down into it, I swirled it around and the debris churned up. So I discoverd that I have a yet undetermined number of "pits" or "divots" in the bottom of the pool liner that debris has collected in. I assume this is not normal. Other than bing a pain to keep clean, is this a major problem?
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Inherited Pool, Pits and valleys in the liner bottom.
    It's not a major problem The liner is being stretched more in those areas and that will shorten the life of the liner some. The only fix is to remove the liner and retrowel the floor (I suspect you have a sand bottom under the liner). If you can live with the 'moon surface' effect, I'd let that liner last as long as it will and retrowel the floor when you install a new liner.
    Luv& Luk
    -Ted
    Guest
    Ok thanks, It might just be eaiser to finish vacing what I can and then get in the pool to manually clean out the perfectly termed craters with my hand and the vac. It is safe to get in the pool with this debris as long as it is at shock level right?
    Mar 2007
    4,160
    As long as it's at or below the shock level for your cya level (see chart linked in my sig) you're OK to get in (though if your cl level is at the full shock level on the chart, I'd wear an old swimsuit ).
    Luv& Luk
    -Ted
