Thread: New to trouble free pool. Have some problems.
    Apr 2011
    Yelapa, Jalisco, Mexico
    25
    Hello everyone. I am in Yelapa, Jalisco, Mexico. Near Puerto Vallarta. My pool was built two years ago and I have had problems that I believe relate to having to use triclor. Logistically it is very difficult to get large quantities of liquid bleach to my location as everything has to come by small boat. hence the triclor. Also, the bleach that I have found here does not list any percentages. I have a tf-100 test kit which I just got. Here are the first test numbers taken today.
    FC 1.5
    CC .5
    TC 2.0
    pH 7.8
    T/A 150
    CH 130
    CYA 90
    Water Temp 90
    Air temp 85
    I have two questions: Is there a way to continue to use Triclor and not have my CYA levels get any higher? And to lower that level? Also I have included two pics. One is of some kind of growth in the grout that I just can't seem to get out? Any ideas or suggestions would be much appreciated.[attachment=0:wbge13b4]IMG_2906.JPG[/attachment:wbge13b4]
    10,000 gal, IG, small tile on total pool, Interwater Sand, 2 hp hayward EcoStar variable sp
    Aug 2010
    Dallas, TX
    4,052
    Re: New to trouble free pool. Have some problems.
    You don't have near enough FC for your CYA level.
    You can't use Triclor and keep CYA stable.
    The way to lower CYA is to partially drain your pool.
    Out of curiosity, would it be easier to have a salt pool and a salt water chlorine generator? Your CYA level is pretty close to being where it needs to be for a SWCG, and if you can get salt it might be easier than trying to locate bleach.
    Apr 2011
    25
    I have never researched a SWCG. Finding it to buy could be a problem and I have no idea of the cost of the equipment. Thank you for the suggestion and I will look into the possibility.
