Results 1 to 13 of 13
Thread: No suction from both skimmers!
    May 2011
    Annapolis, Maryland
    7
    Hi, My pool was just opened and the crew left the skimmer valves off because the h20 level was not high enough...came home filled to mid level of skimmers and turned
    on valves to pump. But I have noticed that there is not much movement of the debris in the pool twrds the skimmers. I removed baskets to feel any suction (usually I am afraid I will lose a hand)
    but there is minimal suction. What should I do?
    Dixtricity
    30,000 gal
    inground/plaster
    salt generating
    sta-rite modul filter
    polaris
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,652
    Re: NO SUCTION FROM BOTH SKIMMERS!
    Check the pump strainer basket for debris and see how much water pressure your return line is putting out. Does it seem normal? If you have a bottom drain, is it all the way open?
    May 2011
    Annapolis, Maryland
    7
    have cleaned out the strainer basket, the water pressure seems fine, the main drain valve is all the way open. I did try to vacum the pool by attaching hose and turning off the main drain and shallow
    skimmer valves, when I did this the pump strainer water level dropped
    30,000 gal
    inground/plaster
    salt generating
    polaris
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    Sounds like you trapped a lot of air in the skimmer lines by leaving the valve closed. Turn off the pump, open the lid to let the water in the skimmer lines equalize to the pool level(you might want to close the drain valve first, to preserve your prime). Then close the skimmer line, put the lid back on, open the drain line and start the pump, Once the pump is fully primed by the drain, s-l-o-w-l-y open the skimmer line.
    I hope this does the trick for you
    Luv& Luk
    -Ted
    May 2011
    Annapolis, Maryland
    7
    Thanks Ted I will try that and let you know
    30,000 gal
    inground/plaster
    salt generating
    polaris
    May 2011
    Annapolis, Maryland
    7
    Did as you said...still have low suction in both skimmers, any other suggestions??
    30,000 gal
    inground/plaster
    salt generating
    polaris
    Mar 2007
    4,160
    Re: No suction from both skimmers!
    I may have been a bit hasty in my describing the method
    When priming a pump, it's best to do it one line at a time. Your MD line is already primed so when you go to open another line, do it slowly and one skimmer at a time. Crack the valve to let a little air be visible in the pump strainer and wait until there is no more air in the strainer before doing the same to the other skimmer.
    If this doesn't work - make sure the plugs were removed from the skimmers .
    If it still isn't working, there may be an obstruction in the line that joins the 2 skimmers.
    Please keep us posted
    Luv& Luk
    -Ted
    May 2011
    Annapolis, Maryland
    7
    thanks will give it a try...one thing I am noticing is that there is an increase in the airbubbles in the pump strainer after all is said and done
    seems like more than usual...is this a problem?
    Your response is much appreciated
    Thank you!
    30,000 gal
    inground/plaster
    salt generating
    polaris
    Apr 2010
    Philadelphia, PA
    92
    Does your skimmer have the movable block off plate? Maybe it's switched right now to cover the suction line?
    Doug
    Mar 2007
    4,160
    If it's affecting both skimmers, check the common fittings for an air leak (there's an article on leaks here).
    However, to have little to no suction from both skimmers, it'd be a larger, and therefor easier to find, leak.
    Keep the updates coming and we'll help you figure out what's going on
    Luv& Luk
    -Ted
    May 2011
    Annapolis, Maryland
    7
    Ted you got it! There was a leak at the pipe fitting where it attaches to the pump. But I did have to pay for a service call , I didn't want to crack the pipe trying to loosen it,bummer but oh well...
    Thanks to all of you for your replys and suggestions,.
    So glad I found this site.
    Sally
    30,000 gal
    inground/plaster
    salt generating
    polaris
    Apr 2010
    Phoenix, AZ
    44
    Sally,
    So glad you solved your problem!
    Maybe you can help with mine, because I have a very similar problem.
    How did you go about discovering the leak at the pipe fitting?
    Thank you!
    10k fiberglass lined IG (over ???), pool dates to 1973, Pentair 1hp superflo pump, Hayward 36SqFt DE filter, Hayward 2025 Ultra Vac, BBB disciple
    Mar 2007
    4,160
    Quote Originally Posted by BelLa's Pond
    Sally,
    Thank you!
    Try the link I gave above Dribble water over any suspect connection for ~1 min. and check the pump lid to see if the bubbles lessen.
    Luv& Luk
    -Ted
