Thread: chlorine too high
    Apr 2010
    Stockbridge, Georgia
    17
    chlorine too high
    all of my levels are right on the money according to the pool school..My only question is once you do the overnight test and your chlorine starts holding then how do you get it to drop back down.. my cya level is right so the sun isnt taking it down.. and there is no organics so im not losing anything there.I know this is a good problem to have and im sure there is a simple answer.My chlorine is holding now at about 19 and i want it to be about 4 or 5
    23000 gallons
    hayward sand filter
    inground vinyl pool
    circu pool rj45 salt system
    22,543
    Re: chlorine too high
    If you turn the swcg off for a while it'll come down. Trust me, no matter how high your CYA is the sun will burn off the FC.
    You did have the swcg turned off when doing the OCLT, didn't you?
    Apr 2010
    17
    yes i did.. ok i will try that then thanks!
    23000 gallons
    hayward sand filter
    inground vinyl pool
