Thread: FC and solar blanket
    Apr 2011
    Iowa
    23
    What would you say is the upper limit for FC to leave the solar blanket on a pool? Another words, if I get my FC up to 6 and leave the cover on am I safe? How about 8 or 10? I would think nothing over 10 would be good but what do you think? CYA is 0.
    16X32 AGP 6' deep end. 15,000. 1HP pump. 160 SqFt solar panels ground mount. 250lbs sand filter (aqua star)
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: FC and solar blanket
    With CYA at 0, FC of 6+ is really high and I would not use the solar cover. As long as you are below shock value, per the FC/cya ratio chart, you can use your blanket.
    Is this an indoor pool? You should have at least 20-30ppm of CYA in your pool.
    Apr 2011
    Iowa
    23
    Outdoor pool. I just received 12 lbs of cya yesterday. I'm shooting for a cya of 40 when I add it.
