Thread: what do i do after shock process?
    Jun 2010
    Dayton, Ohio
    241
    Once the pool looks good and test results are good how much bleach do I need to add to my pool and how often? I know it has to do with how often pool is used and sunlight and such but is there a general idea of how often and how much I will need to add bleach?
    AGP: 24' x 52" cartridge filter: 13,500 gallons. Taylor K-2006 test kit.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Re: what do i do after shock process?
    If you've already shocked..........you know what your CYA level is I presume? If so..see the CYA /Chlorine chart in pool school to see what your recommended range is for that level. You can play with the pool calculator to see what effect adding a certain amount of bleach to your volume of water will have. Expect to lose on average 2-3ppm of FC per day. Your pool may vary depending on bather load and amount of full sun.
    Apr 2011
    Somewhere on the Emerald Coast
    156
    woodyp is correct - use the pool calculator. I'm still coming out of "green swamp mode" so I'm testing every other day. I expect to test twice a week once I'm balanced (the POOL !! ... not ME !!)
    20,125 gal. (2,690.6 c.f.) In-Ground / Concrete (Gunite) / Pentair Tagelus TA-60-60D Sand Filter / Pentair Whisper Flo Pump Model WF-24 @ 1HP / Hayward Veri-Flo Valve Model 710 / Taylor FAS-DPD K-2006 test kit / Pool School student
