Thread: Electronic tester recommendations sought
    Oct 2010
    Eastern TN
    173
    O.K., getting lazy. Looking for an easy tester for salinity and pH.
    Would this be good for salinity: http://www.amazon.com/HM-Digital-Handhe ... 416&sr=8-4
    What would be good for pH? My TF-100 kit will not read above 8.2 and I need something that will.
    Plaster pool inground 22,000 gallons with spa. Pentair Intelliflo, IC40 salt generator, WiFi control/Easy Touch.
    Hayward 1.5 HP pump on 750 gallon spa. Sand filters. Auto chlorinator on spa. Auto water level. Dolphin M500. TF100 XL with Speed Stir. Apera Instruments AI311 PH60 Premium Waterproof pH Pocket Tester
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Re: Electronic tester recommendations sought
    You don't want your PH to be at or above 8.2 in the first place. If you think it is testing higher than that, just use the pool calculator to Assume it is that and adjust it down to the recommended level. Retest and repeat if necessary.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    I rarely test salinity (maybe monthly) to find using accucheck strips a nuissance. On the PH, why would you want to measure PH above 8.2? You should really keep pool water PH between 7.2 and 7.8
    Oct 2010
    Eastern TN
    173
    I'm trying to use the pool calculator to figure out how much acid to add but if I don't know the true pH then I end up adding too little acid.
    Apr 2010
    East Texas
    9,659
    It's kinda like the instructions on a shampoo bottle.
    Lather, Rinse..........and REPEAT if necessary!
