Thread: No/low pressure on filter
    Jul 2010
    Midland, MI
    12
    Help?!?!
    I fired up the pump/filter for the first time this season and I'm getting no or very low pressure on the filter's gauge.
    I let all the air bleed out so it's a constant stream of water. The return seems to have good water pressure coming out of it back into the pool. Nothing seems to be leaking. I let it run 2-3 minutes and then turned it off so nothing would get ruined...
    Any ideas why I'm not getting a pressure reading?
    26.7k gal. 33' AG AquaLeader Influence, Hayword Power-Flo LX 1.5 HP pump, Hayword HeatPro 140k BTU,
    SwimPro Voyager filter, Hayword SP1091 Dyna-Skim Auto Skimmer
    Re: No/low pressure on filter
    Your pressure gauge is probably broken. Those gauges break easily. Fortunately, they aren't very expensive to replace.
    Jul 2010
    Midland, MI
    12
    The filter is less than one year old - do the gauges go bad that quickly? Is there any way to test the gauge itself?
    The only other thing different from last year is we installed a new heat pump, but as I said - the return pressure seams normal (like before the heat pump was in place)...
    Thanks!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Quote Originally Posted by omster
    Thanks!
    I've never had a gauge survive a winter outdoors. They are cheap junk.
    Jul 2010
    Midland, MI
    12
    We stored the filter/pump in the garage for the winter (Michigan) - do you think the gauge is bad? Any way to test?
