Results 1 to 7 of 7
Thread: How do I re-aim the return jet eye-ball
    Puffin's Avatar
    Jul 2010
    Metro Atlanta, Georgia
    217
    Ok, I feel kinda dumb for asking this but, how do I move the little eyeball in the return jet? At first I thought that I just had stationary ones return jets, then I took one off and looked in the back. There is a ball that is held in between a bezel and the part that threads into the wall. Is there some kind of tool you use to re-aim them or loosen them?
    I know, it seems like something that should be obvious. I feel like this is one of those, "...he doesn't know how to use the 3 shells..." kinda things.
    19,600 gal, Vinyl, Grecian L, StaRite Dura-Glas 1 HP pump, 3/4hp booster, Pentair Clean and Clear 420 Cartridge filter
    The Pool Cleaner 4x, PoolSkim
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: How do I re-aim the return jet eye-ball
    The retainer is two pieces. Loosen the outer piece and the ball will move.
    crookm11's Avatar
    Jun 2010
    Copperas Cove, Texas
    422
    The part that threads in to the wall should stay where it is at. Losen the bezel and the eyeball should move.
    Mark Crook
    13,500 Gallon 24' x 52" Intex Ultra Frame
    Intex Sand Filter and Pump, Intex SWG (All hard PVC plumbed)
    TFTestKit-100---Pool School---The Pool Calculator
    Location: Copperas Cove, Texas --- My Pool Build---Useful Links for Intex Pool Owners
    Puffin's Avatar
    Jul 2010
    217
    So the bezel is just threaded in place? no weird locking clips or something.
    I tried just unscrewing it (it was my first thought), it must have been over tightened. I'll try one of those strap wrenches or some channel lock to get some leverage.
    Thanks.
    May 2011
    lebanon tn
    370
    you may have to turn the pump off- sometimes the water jet will hold the eyeball in place against the nut...
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
    A strap wrench is much better than channel locks, the channel locks can tear up the plastic if you aren't careful.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Before breaking out the heavy equipment (channel locks or a strap wrench) - try using a screwdriver in the hole as a lever to adjust the direction
    Luv& Luk
    -Ted
