In-ground liner options.
May 13, 2011
41
I currently have a large in ground pool w/ a vinyl liner, which needs replacement. I would like to go with a higher end finish if possible (and budget allowing).
I purchased the home as a foreclosure and the pool is boarded up, so I don't know too much about it, but I believe the walls are cinder block. Do I have any more lining options, or am I stuck with using vinyl?
crookm11 said:
WElcome to TFP! :wave:
I'm not sure about what options you have but posting some pictures of your pool may help in determining what options may be available.
:cheers:
Thanks for the welcome! The pool is boarded up so there's not much to look at, but here you go.
I was able to sneak a peak under the cover. As expected, the whole thing needs to be redone.
Switching from vinyl to plaster or pebble would be a major renovation, about the same as building a new pool from scratch. Putting in a new liner shouldn't be too difficult. The main question: Is the underground plumbing intact or not.
I would probably opt for new plumbing to be run when the pool was re-lined. Is it a major overhaul to do so? I didn't really care for the location of the filter, so I was hoping that could be rerouted elsewhere.
One word of advice, go with a premium level liner, they hold up much better than the standard grade liners. My current liner is a premium grade liner and is about 7 or 8 years old and still looks great. The liner that was in the pool before the current one was a cheap standard grade liner that lasted less then 5 years (it was put in as an unplanned emergency replacement due to an incident with an golf cart style ATV in the pool, the front bumper put a 5 foot long gash in the liner in the shallow end)
Ike
