Thread: Stain on liner floor
    Aug 2008
    Hebron, CT
    79
    Hello,
    I am beginning my 6th season as a pool owner. This was the first time there was a softball sized orange/rust colored stain in the deep-end of the pool after I did my initial cleaning. My pool opened quite clean (it always does) with the exception of a few leaves and several worms and bugs. The water is always quite clean after 7 months of dormancy. This was the first time there was a “stain” though. This is in the deep end of the pool and brushing it has zero affect. I have yet to manually get close to the stain to try and clean it (water is only 62 degrees!) but I will try soon. However, I have a feeling it is going to be a stubborn stain. Any suggestions? Thanks!
    22,500 gal Lagoon shaped inground pool, vinyl liner, Hayward 4800 DE Filter, Hayward 1.5 HP super pump, Aqua Heat Pump, Nexus Pure SWG, Dolphin Triton PS, Hebron, CT
    Re: Stain on liner floor
    Try placing a vitamin C tablet on the stain and see if that does anything.
    Aug 2008
    Hebron, CT
    79
    Worked like a charm. Thank you!
    That means there is iron in the water. You might want to use some sequestrant reguarly to prevent stains from reappearing later.
    Aug 2008
    Hebron, CT
    79
    OK- Thanks! What is sequestrant? I have never added that before. Do you have tips on how often/how much to add over time and where to buy it?
