Thread: epoxy coating peeling off
    after fixing the water as clear as crystal. now i can see some area comes off because the automatic cleaner.
    have to empty the pool to fix?
    Yes, properly fixing that will most likely require sand blasting which means draining the pool. Generally any kind of paint coating, epoxy or otherwise, is not usually a good idea because it makes such a mess when it wears out.
