Results 1 to 8 of 8
Thread: Can't get rid of cloudiness...frustrating...latest test #'s
    Apr 2010
    Syracuse, NY
    103
    Opened the pool late last week, and a lot of ground water/dirt had gotten into the pool from the April rains. The whole bottom of the pool has a layer of brown mud on it. I finally vacuumed the shallow end, and only part of the deep end, because I can't see the bottom. I did what I could. Tomorrow I'm hoping to vacuum more if I can see more of the bottom. Even though there is mud on the bottom, I was assuming the pool would basically clear, except for the layer on the bottom. I'm also currently shocking the pool and these are tonight's test #'s. FC-24, TC-24.5, PH-7.0, T/A- 90, CH-100, CYA-60. I know a few of the #'s are a little high or low, but not too out of whack. I still thought the pool would clear better. I can't see past 4' down. It doesn't seem to matter whether I run the pump or not, the cloudiness stays the same.
    20,000 gal., Jacuzzi 250L Laser Sand Filter, inground w/vinyl liner, 1hp pump motor, TF-100 Test Kit.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Can't get rid of cloudiness...frustrating...latest test
    With mud in the pool, I'd think you might just need a little more patience. Run your pump 24/7 and vacuum all you can, even if you can't see. It may get worse before it gets better since vacuuming will stir up some of the dirt.
    Apr 2010
    Syracuse, NY
    103
    I'll keep running the pump. Should I keep the Chlorine at shock level also? Would pictures help?
    Yes, stay at shock level, and vacuum up everything you can, even if you can't see what you are doing.
    May 2011
    lebanon tn
    370
    Are you vacuuming to waste, or filter?
    What type of filter?
    you should be able to clear this, with a little time/effort...
    Wouldn't worry about your numbers- watch the pH to make sure it doesn't go lower (if 7.0 is lowest on your test, you may need to boost it a little, since you don't know if 7.0 or less...)
    If your FC holds over night (<1 ppm loss from dusk to dawn) then with your CC of .5 (TC- FC) I would guess that it is all just dirt keeping it cloudy- not an issue with growth, just filtering it out... will just take time to get it all into the filter instead of the pool bottom!
    If it settles significantly, you can try to vacuum to waste to get rid of it- then refill water...
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
    Apr 2010
    Syracuse, NY
    103
    Definitely vacuuming to waste. We have a sand filter w/new sand last year. Pressure runs about 10 psi normally. The pH is currently 7.0, and it goes up a little every time I vacuum a couple thousand gallons to waste and refill with 8.0 hose water. So the pH should be 7+ by the end of today. Once I am satisfied that I have everything (dirt, leaves, worms, etc.) vacuumed, I'll check the FC loss overnight. Thanks for all the help. Time to vacuum! To be continued.....
    Apr 2010
    Syracuse, NY
    103
    I vacuumed the pool 4 times. The pool is definitely clearer, but still cloudy. I'm almost convinced that the cloudiness is very fine suspended dirt particles, and that they are passing through the filter. Is adding some DE to the sand filter an option to help filter out the finer particles?
    Yes, adding a little DE to a sand filter is likely to help speed things up.
