Thread: Subscripts and Superscript are bigger
    Mar 2007
    San Rafael, CA USA
    12,082
    At some point the subscripts and superscripts either got bigger or moved to not be below or above the main character line. This makes chemical formulas look much worse such as H2CY-. If you could put this back to the way that it was, that would be helpful. I suspect the change was so that subscripts and superscripts wouldn't increase the line spacing, but it makes such subscripting and superscripting look worse.
    Re: Subscripts and Superscript are bigger
    2*X3+1 H2O
    It looks just the way I remember it looking. Nothing has changed in years. It still uses the HTML sup and sub commands, and it is then up to your web browser to render them appropriately.
    What web browser are you using?
    It helps if you put the equation on its own line. Also, you can use the size function if you want to change the size.
    H2CY-
    Support the site
    Mar 2007
    San Rafael, CA USA
    12,082
    Aha! You hit the nail on the head. It's my browser. Safari looks fine, but Firefox that I just upgraded to 4.0 (4.0.1 actually) no longer looks the same! I don't see any Preferences option that would bring things back to normal, but at least I now know what it is -- it's the browser. Thanks for figuring that out.
