Thread: Let's check my numbers
    Aug 2010
    Dallas, TX
    4,052
    This is the first time in a while I've posted my full number set. I do have one quick question, so here it goes!
    FC 4
    pH 7.5
    TA 80
    CH 340
    CYA 40
    Temp 76
    CSI -.06
    I believe poolcalculator.com recommended 100 for TA, but 80 seems good to me, correct?
    In fact, these numbers look great to me, so I thought I'd just make sure.
    Re: Let's check my numbers
    Those numbers all look good. For bleach we recommend TA between 70 and 90, so you are good there.
    Aug 2010
    Dallas, TX
    4,052
    OK thanks, that was the only thing I had a question about. Good to see that it is holding right. I am loving the BBB method! Honestly, for me it has been the "B" method. I haven't touched the other two!
