Thread: Amount of salt for start up
    We are in the process of starting up our intex 24' x 52" pool with intex sand pump/filter and intex chlorine generator. We are struggling! We have added the amount of salt suggested in the manual but it keeps reading low salt. We have added another 40kg as the manual suggests. Can anyone tell me how much salt is needed for starting up the pool.
    Many Thanks
    Intex 24' x 52" metal frame AG pool.
    Intex sand filter with 0.95hp pump.
    Intex saltwater chlorine generator.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: Amount of salt for start up
    Is this a new chlorine generator? What is the current water temperature? How is the water flow through the pump?
    Love TFP? Become a
    TFP Supporter!
    Please tell us how much salt you added in total.
    tsunami's Avatar
    Sep 2008
    Oceanside, CA
    138
    Give the salt a minimum of 24 hours to dissolve. Brushing helps. My SWG says to run the pump for 24 hours after adding salt. Then check the reading.
    40 X 26 Free Form Pool with attached 9 X 7 Spa raised 18" with 8 Jets and Spillover, and an Art Rock Waterfall/Grotto with accent rocks, 26,000 gallons
    Intelliflo VF-3050 for Pool, VS-3050 for Spa Jets, VS-3050 for Waterfall/Grotto, Quad DE 80, 400K BTU Mastertemp, Intellitouch i7+3 w/ iS10 10 Function Spa-Side Remote, Intellichlor IC40 Salt Chlorinator, Telephone Remote, 2 Intellibrites for Pool/ 1 for Spa, Solar Panels on 2 story Roof w/ 75% coverage
    Pebble Tec Tropical Breeze Tsunami's Pool Build
    ThePoolNinja's Avatar
    Apr 2011
    Southern California
    61
    Sometimes if the Cell is dirty, your Salt System will keep reading low salt and not generate. Try cleaning it if you believe you have enough Salt in your pool. I'm not sure what salt level the Intex system is set to generate at. Most salt systems generate at a minimum salt level of 2700. And as mentioned above, if your pool water is too cold (say under 60 degrees), some systems won't produce at that temp.
    Thank you very much. I cleaned the cell and it worked!
    Kerry.
