Thread: Reviving an empty tub
    May 2011
    Austin, Texas
    14
    Hi All,
    I've just moved an the house has a hot tub. It's currently empty and in questionable health.
    What's the process I should follow to get it filled and see what works? Are there certain things I should check first? Should I be cleaning the inside with something before filling it?
    Cheers,
    Alan.
    10,000 gal, IG, small tile on total pool, Interwater Sand, 2 hp hayward EcoStar variable sp
    Jan 2009
    Cupertino, CA
    1,966
    Re: Reviving an empty tub
    I recommend these two posts:
    How do I use chlorine in my spa
    Spa Decontamination
    --paulr
    BBB "Intermediate Swimmer"
    May 2011
    Austin, Texas
    14
    Hi Paul,
    Perfect - thanks. Would you recommend using chlorine rather than bromine in a spa?
    Cheers,
    Alan.
    Jan 2009
    Cupertino, CA
    1,966
    I've used the dichlor/bleach method with great success. It does mean you need to be keeping an eye on the levels at least every couple of days even if you're not using it. This season I'm using bromine because I know I can't be checking on it as often as chlorine requires. Word is that bromine is more expensive; I haven't been using it long enough to tell for sure how long a bottle of bromine tabs will last, so I haven't formed an opinion.
    --paulr
    Mar 2007
    San Rafael, CA USA
    12,082
    Basically, if you are using the spa every day or two, then chlorine is easy since you just add it after your soak. However, if you only use the spa infrequently, only once or twice a week, or you have frequent times you are away from the spa, then bromine is easier since the bromine tabs keep a background bromine level for you, usually up to a week.
