Thread: Fill with pond water??
    Jul 2010
    NE OHIO
    11
    I saw that some have done this, but I wanted some wise words on whether or not we should. We were thinking of filling our pool the rest of the way with water from our pond. We have an above ground pool that is 30 feet across. We need about 12 inches of water. If I figured right that should be around 5300 gallons of water. This is only the 2nd year we have had the pool, so I don't know too much. We wanted to take water from the pond off the end of our dock, so we wouldn't pull things from the bottom. We would use panty hose at the end going into the pool to catch anything we happen to suck up. Does this sound like it will be ok?? Would we need to shock the pool after this. I haven't checked any levels yet, but I would guess the CYA level is pretty low.
    30' Round AGP, about 22,000 gallons. 1.5hp pump. Cartridge Filter. TF-100 test kit.
    Re: Fill with pond water??
    Yes, you should be able to do that. You will certainly want to shock after you are done filling.
    Jul 2010
    NE OHIO
    11
    Great!!! Hopefully we won't need to though. I went to walmart to get my bleach and Conditioner, came home and my husband said it rained while I was gone and the pool went up 1 1/2 inches. Then got another storm that went through and gained another 3 inches. More rain is expected the next couple days, so maybe we can get it high enough to start to run the pump! Was well worth running a pipe from our gutter to the pool. I love not having to buy water
    May 2011
    lebanon tn
    370
    Not really swimming pool related, but pond related
    My Grandfather owned a 40 acre lot outside of Atlanta, with 2 ponds on it.
    He used the ponds as the water supply for his greenhouses (commercial greenhouses, growing poinsettas, mums, and Easter lilies)
    Pond water is fine for most purposes- probably not for consumption without some treatment, but everything else if probably fine!
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
