Results 1 to 7 of 7
Thread: stuff that gathered on pool floor
    Jun 2010
    Dayton, Ohio
    241
    I am getting water chemistry under control but I do have a question. I want to do whatever is easiest.... I can see my pool floor and can see where gunk has gathered not sure what it is leaves, dead algae...who knows but should I stir it up and hope the filter gets it or should I try to vacuum it out?? whatever works best is what I hope to do.
    AGP: 24' x 52" cartridge filter: 13,500 gallons. Taylor K-2006 test kit.
    Aug 2010
    Dallas, TX
    4,052
    Re: stuff that gathered on pool floor
    Try to vacuum it out by whatever means you have. I use one of those hose-end pressure leaf baggers since I don't have a vac. The stuff on the floor is going to eat chlorine as well, so you'll spend more time and money shocking than you would if you have it all cleaned up.
    Jun 2010
    Dayton, Ohio
    241
    okay....I will try to hook up vacuum and get it out. Pool water is so cold! I hate to touch it!!
    May 2011
    lebanon tn
    370
    definitely get as much solid **** out you can with vacuum or net or whatever...
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
    Jun 2010
    Dayton, Ohio
    241
    I am not sure how solid it is.....I will stir it up and see what I am working with.
    Jun 2010
    Dayton, Ohio
    241
    I hooked up the vaccum yesterday and what was a blue pool with some stuff on bottom is now very cloudy,greenish color....cant see bottom at all. I am keeping pool at shock level. Is there anything else I need to do or will it start to clear back up?
    Rockland County, NY
    52
    It is normal to kick up some sediment and debris when vacuuming which in time will be sucked up by the filter. Taking your time will reduce the amount in suspension. Run the pool filter 24/7 until you have completely vacuumed the bottom and the water is clear.
    22,000 gallon ig vinyl solar heated (panels and cover) zeolite filtrate
