Results 1 to 10 of 10
Thread: Add bleach? Confused
    Sep 2010
    South Mississippi
    27
    Here are today's numbers:
    FC .5
    CC 0
    PH 8.2
    TA 110
    CH 360
    CYA 45
    temp 86
    Salt 4000
    Salt has been running high and im going to turn down the SWG from 50% to 40% today.The pool calculator doesn't say to add bleach but it seems as it's low I should.... Waiting on you experts to give me the low down- thx!
    20,000 Freeform IG Gunite,Gray Plaster,Tanning Ledge w 2 Bubblers, 8f tRaised Spa with 8 jets,Fiber Optic-3 ft Sheer Decent, 1 ft Sheer Decent, Intellibrites, 2 HP Jandy Stealth Pump, 1 HP Jandy pump, 340 Jandy Cartridge Filter, Jandy Aquapure Salt System, 2-1HP Blowers....and promised but not yet delivered Rheem 105 BTU Heat Pump/Chiller
    Voodoo_Pool's Avatar
    May 2011
    On the border AR/TN
    82
    Re: Add bleach? Confused
    Based on your CYA of 45 you should target between 5 and 6 ppm chlorine according to the CYA/Chlorine chart. I would add bleach (chlorine).
    I am curious, why would turn down your SWG because the salt is running high? I would think you should do just the opposite because your FC is low. But then again, I do not have a SWG so I will leave that to those that do.
    Temp is 86. Get in the water!
    IG Vinyl 27,000 gallon "L" shaped (new vinyl April 2018) with spillway spa; Hayward 4820 DE; Polaris 380 w/ booster; TF-100 Test Kit w/SpeedStir
    There are a couple of different things that need adjusting here. First, lower your PH to 7.2 and always keep your PH below 8.0. Lowering PH will start to bring the TA down. You want to continue lowering PH to 7.2 every time it gets to 7.8 until your TA is below 80.
    Your CYA level is way to low for use with a SWG. You want to raise CYA up to around 70 to 80. At low CYA levels the SWG can't keep up with chlorine loss due to sunlight. Once CYA comes up the SWG will do much better.
    Finally, SWGs are not designed to bring the FC level up from zero. You should manually add some chlorine to establish a normal FC level and the SWG will have a much easier time keeping up from there than it will trying to raise FC up from zero.
    Sep 2010
    South Mississippi
    27
    Ok- will do! Knew I could count on you! It's been really warming up here in the last week so I'm sure that's added to things....Plus I've not been staying on top of things( testing properly) sheepish grin
    Sep 2010
    South Mississippi
    27
    Also Jason the SWG has been running high and till last week has had the chlorine high(4300) and it's been shutting down to protect itself.... Chlorine levels plummeted though this week...guessing due to higher temps/sunnier days.....have had no rain in months...we're in extreme drought here in South Mississippi
    30,432
    JL,
    You are confusing salt and FC.
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    4300 is not the chlorine level, thats the salt level in the pool. Turning down the generator has nothing to do with lowering from 4300. Going down is going to lower the FC (.5). If you want to lower your salt level (4300) your going to have remove and replace some water from the pool.
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    The pool calculator won't tell you to add anything unless you give it "what it is now" and "what I want for a target" values.
    Sep 2010
    South Mississippi
    27
    Sorry, I meant to say that the high salt levels(4300) seem to have been keeping my FC high...does that sound right?The high salt was also trying to shut down the SWG(or going into safety mode).....now this week the FC fell really low but it's been much hotter and sunnier this week. When I plugged the .5 into the pool calculator w a target of 5 nothing happened after I hit calculate....thought I was going nuts as I figured I needed bleach. Maybe it just didn't register. With all that said I recalculated tonight (on pool calc) & it said to add bleach. Phew. I will add water, bleach & more stable- sound right?
    May 2011
    On the border AR/TN
    82
    So...did you raise your CYA? That should make a difference for you pool's chlorine "addiction". So what are your "today's" numbers for pool chemistry? Up to date numbers for chemistry are always good for "good" advice on this forum. Thank you.
