Thread: black pool liner ??
    black pool liner ??
    I have been looking and can't really find much on black pool liners. Most of the darker ones are for inground pools not above ground. Does anybody know where I can find either a black or really dark colored liner for a 15ft. round 52" pool?
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    Isaac-1's Avatar
    SW Louisiana
    6,704
    Re: black pool liner ??
    One potential problem with black that applies to most black synthetic items is that with time it will fade and become any number of potential colors you may not like such as brown, gray, purple, etc.
    Ike
    Jan 2010
    Randleman,NC
    588
    FADE!!!!I started with a dark liner last year..It faded within a month of use..I quess because it was mark'd down...
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    Lana537's Avatar
    May 2009
    The Triangle, NC
    242
    Remember the effect of the sun on heating up the pool water, especially with a dark liner. Is your pool in direct sun? Maybe you want it that way for that reason? Algae growth and other troubles might be difficult to see with a dark pool--cleaning dead leaves, branches, and dead critters.....
    Lana
    23,600 gallon, refurbished 1960's inground concrete, Jandy sand filter w Jandy 2 hp variable speed pump, Pool Pilot Digital SWCG+Chemtrol 2100+CO2 tank; PebbleTec White Pearl with 10% Cobalt Blue Dark Beadcrete by Olympic Pool Plastering, Georgia. Taylor K-2006 Test Kit; Aqua Check Salt test; LaMotte borates test, and Jack's Magic Sequest test kit; SparklyPoolitis level: extremely high.
    I emailed northwest wholesale and they say that black liners are not available for above ground pools. The main reason I wanted black was I seen a black inground pool a while back and I liked the way it looked plus our pool doesn't heat up as much as other pools since it doesn't get early morn or late eve. sunlight. I can't afford a propane heater and just looking for other inexpensive ways to heat the pool.
    Pool School
    Pool Calculator
    Test Kits
