Thread: ok... just some more numbers...
    Baton Rouge, LA
    237
    18,000 gallons in gunite, 2-3 months old
    FC 2.5
    CC 0.0
    TC 3.0
    pH 7.5
    T/A 100
    CH 380
    CYA 50
    Temp 84
    Salt 4000 ish (depends who I believe... but I'm not adding anymore... and pretty sure the rain will bring this down soon enough)
    From what I've read, everything looks ok, right? Is the FC at 2.5 high enough? No aglae as of yet.
    Water looks good.
    I wouldn't mind not having to add about 8 oz's of acid every 2-3 days... seems like I've heard there are ways to decrease the acid use.... suggestions?
    Thanks!!
    18,000 gallon gunite free form, with spa, 4x160, EasyTouch, SWCG, Pentair cartr filter, Colorlogic lights.
    If you bring TA down to around 70 the PH drift will be far slower. TA will come down on it's own eventually anyway, so you can either reduce TA or let it come down on it's own.
    FC of 2.5 should be fine, but I like to have a little more margin than that to handle several people swimming or other unusual events. I would only go a little higher, perhaps aiming for 3 when measured in the late afternoon/evening.
    FC plus CC should equal TC. One of those three numbers is wrong.
    Baton Rouge, LA
    237
    Thanks Jason,
    my typo... CC is 0.5
    I'll just let the TA slide down on its own then.
    I run my pump/swcg about 7 hours a day (3pm - 10 pm), and I did my testing right before it clicked on, so I guess I tested it right at its lowest point.
    I usually do my ph/cl test in the morning, but admit to sometimes not being able to interpret it very well, but I think its somewhere around 3.
    So I'll just keep doing the same things...
    thanks again, Jason. You're much help!!
