Thread: Pool automation
    Feb 2011
    Fort Worth, Tx
    22
    Pool automation
    I have been looking at automation and it seems there are many out there.
    What are people using and do you recommend it? We need at least 10 auxiliary connections for pool equipment so it threw the jandy aqualink pda out the door after talking to their rep. We have all Jandy equipment and never lube valves so I have the ability to move stuff around.
    I want to be able to program modes so that it will control various components with a single touch that I can program through my PC if needed.
    Raymond
    Gunite IGP, 3.5'-7.5', 21'X39.5', Jump Rock, 32' Weeping Oklahoma Creek Rock Wall, Sunstone - Black Onyx/Blue Mist ( 3:7 bag mixture ), Pseudo Spa with no heat just jets and air, Tanning Ledge, Gecko mosaics, Umbrella Pole, 2- Bubblers, 2 - Spray Fans, 2 JAndy LED lights, 2 - Jandy 1.5 hp stealth pumps, 1 - Waterco Centrifugal Filter, 1 - 580 Cartridge Filter, Oklahoma Flagstone Coping
    Textured colored concrete
    Re: Pool automation
    Controlling ten relays is going to require a fairly high end system, perhaps a Hayward ProLogic PS-16 or a Pentair IntelliTouch with expansion cabinet. I like Hayward better, but they are both good.
    Aug 2010
    Austin, TX
    200
    Re: Pool automation
    Quote Originally Posted by doopie
    Raymond
    Tell me more about what specifically the connections are. You can control up to 24 with an aqualink, just need to buy a big enough unit. The "Palm" remote works with any version, but for larger systems you still need a oneTouch or Touch as the main controller to do the programming. The RS8 and lower can be had with a special version of the Palm that can be used as the main controller, but even then it's limited in what it can setup. I have an RS12, which can control 12 relays or combination of relays and actuators. I use a Palm to control the devices on/off and set temps when we're outside by the pool. Inside we have a Touch that sets the schedules and that I use to setup the system. Everything has been surprisingly simple to wire, setup and operate, with no hiccups. We have a combination of stuff, works great.
    38K Gallons IG, Intelliflow VS-SVRS, 30GPM 24/7, 72sqft DE Filter, Spectralight UV, Jandy C1900 driving Liquid Chlorine and Acid (toys, I know..), Jandy LXi gas heater, Aquacal SQ175 Heatpump, Riverflow Competition swimmer, Jandy automation, Touch and iAqualink, Pebblesheen | The Build
    Mar 2011
    Scottsdale, AZ
    406
    Re: Pool automation
    Intellitouch all the way.
    Feb 2011
    Fort Worth, Tx
    22
    Re: Pool automation
    After lots of research it looks like I can omit all of the pool company systems and just utilize my Elk Controller to do what I need.
    I looked at the Hayward PS and it seemed promising and had an Aqua link to hook up to my pc/Elk but then I found someone who was able to use all OTS relays to work around it for much cheaper and still one interface so I can use my phone to control everything once configured.
    http://www.cocoontech.com/forums/index. ... opic=12323
    Thanks for the info guys.
    Raymond
    Aug 2010
    Austin, TX
    200
    Re: Pool automation
    Raymond
    Yup, you'll be able to run everything pretty well. Not sure how the ePump works, but if it has a relay for each speed you're set. If not, they probably make a kit to provide the speeds via relays. Temp probes are key. For the actuators (if you have any) jandy makes a relay to JVA converter that requires a 24V AC power supply. If you have cold weather, don't forget a rule for freeze protection!
