Thread: Pool Blaster Catfish
    Jun 2007
    San Antonio, TX
    7
    I have an IG plaster pool with an attached spa. I have always had a problem keeping the stairs and spa floor clean due to leaves and blowing dust. Has anyone had any experience with the Pool Blaster Catfish battery operated vac, or any other similar items?
    http://watertechcorp.com/products-catfish.htm
    Thanks in advance for you help.
    10K Plaster Pool
    Haywood Cartridge Filter
    2 Speed 3/4 HP Pump
    Spillover Spa
    Using BBB Method
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,600
    Re: Pool Blaster Catfish
    I haven't been able to find enough "Good" reviews to justify buying one myself.
    ThePoolNinja's Avatar
    Apr 2011
    Southern California
    61
    I own the Catfish's bigger brother, The Pool Blaster Max which i use frequently to clean ponds, waterfalls, and spas such as yours, and it works well in picking up small leaves, heavy dirty, and sand. It'll pick up fine dirt/dust in a couple slow passes as well. I've double bagged it with fine mesh bags, and it seems to do a good job in picking up the dirt without letting it back through. The Catfish would most likely work well for your application. The Catfish is a step up from the Aquabroom, slightly more powerful.
    Jun 2008
    Marana, AZ
    347
    I have a catfish. I've cleaned the whole pool with it before. It does a MUCH better job than I thought it would. Since we live in an area that has fine dust that blows in the air (hence settles in the pool) I often use a nylon stocking in the bag. Otherwise, it does well with picking up larger grains of sand, small leaves, and other debris.
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
