Thread: Hayward sand filter backwash question
    Hello, my 1st post. I will put up my pool info the next time I get on. My question is: While backwashing, Dirty water is being pushed back into my pool from my pump for the 1st few minutes of backwashing, is this normal?
    Thanks!! Mike in Summerville, SC.
    Thanks!
    Dec 2009
    Central Massachusetts
    2,690
    Re: Hayward sand filter backwash question
    No, that shouldn't occur. Most likely the gasket in your multiport valve needs to be replaced.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Your right. - it sort of hung up the last time I backwashed/filtered and it doesn't turn as smoothly. I didn't connect the dots on that AT ALL. Thanks BK.
    Thanks!
