Thread: Adding DE...am I doing something wrong?
    Denton, TX
    14
    Everytime I add DE lately it looks like it just going straight into the pol and not sticking in the filter. Shortly after a add it my pool gets very cloudy. Any idea what's going on here?
    16K gal, IG plaster, DE filter, 2.5 HP Pentair Challenger
    Dec 2010
    San Diego, CA
    1,137
    Re: Adding DE...am I doing something wrong?
    Probably a torn screen. Or something didn't seat properly the last time you opened it. Did you open it for cleaning just before this started? Regardless, you need to take the filter apart and check for tears andthat everyhing is seated properly.
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    Denton, TX
    14
    I did recently take it apart. I'll check it out. Thanks
    ThePoolNinja's Avatar
    Apr 2011
    Southern California
    61
    What type of DE filter do you have?
    Most likely a small tear in one of the grids, or a small crack in the manifold which may be hard to see. If it's a grid pack, be sure to completely take apart the whole thing to thoroughly check everything out.
    22,550
    While it could be a tear or hole in the grids, I'd say it's more likely that you just didn't get something put back together just right the last time you tore it down.
