Thread: Chlorine Test on Taylor 2006
    While testing free chlorine, I notice that the bottom say 10% of the water stays pink while the top is all clear. IS this normal? Or do I need to keep adding drops until it is totally clear..
    25k Gallon Gunite Inground Pool
    Pentair FNS PLUS DE filter
    Pentair WhisperFlo WF-24 (seems like single speed)
    Bel Air, MD 21015
    Re: Chlorine Test on Taylor 2006
    You should be swirling to mix the sample continuously, so you shouldn't see anything like what you describe. In the end it should be totally clear.
    I am swirling, but like 90% of my water is clear, just the very bottom is pink.. eventually after more drops and swirling it goes away..
    Bel Air, MD 21015
    If it forms a colored layer like that you should slow down on adding drops and keep swirling to mix until the color is uniform throughout the sample.
    Thank you very much Jason
    Bel Air, MD 21015
