Just opening the pool here in Nashville. I replaced the Aqua-Rite flow sensor last fall before closing (thanks to Leslie's for getting part under warranty). Now, it is not working again! I'm thinking there must be another problem. Is there a way to reset the unit?
Also, I took the sensor out and water DOES NOT gush out of the opening - should it be? Others said cork it after taking it out. There is slow but very little. Goldline told me it only takes 11 gpm so that's not a lot.
Please help - need a clean pool and DON'T want to spend lots (more!) money on it! Where do I find the black "thing" (current limiter?) to check?
Thanks in advance for any help!
Deb
Deb
