Thread: Hayward Valve Label :-(
    Jun 2007
    NC
    255
    Can anyone give the label names for the positions on a Hayward multi-port valve from a 210S sand filter.
    My label completely disintegrated over the winter!
    Terry in NC
    Triad Region of NC
    18x37 Vinyl IG (24,000 gal.), BBB & GoldLine AquaLogic PS4 SWG, Hayward 1 HP Superpump / Hayward Sand Filter / Polaris 280 cleaner / 6 deck jets / Sheer Descent Waterfall (in coping) / Brick Red Concrete Coping / Stamped Concrete Deck
    Lots of oak trees, maple trees, *and* leaves!
    Ohio
    217
    Re: Hayward Valve Label :-(
    Terry
    I think the valve you are talking about is mounted to the side of the filter. With the pointer on the handle pointing towards the filter I will call this position 12:00.
    12:00 Filter
    2:00 Waste
    4:00 Closed
    6:00 Backwash
    8:00 Recirculate
    10:00 Rinse
    Hope this helps
    Ric W
    My Pool
    8605 gal fiberglass, 3/4 hp pump, sand filter, aquabot cleaner, heat siphon heat pump, tiger river(sumatran) spa
    Jun 2007
    NC
    255
    Quote Originally Posted by ric
    Terry
    12:00 Filter
    2:00 Waste
    4:00 Closed
    6:00 Backwash
    8:00 Recirculate
    10:00 Rinse
    Hope this helps
    Thanks Ric.
    Those are the positions that I remembered. I've never even used anything but Filter, Backwash, and Rinse to date, but I have to get some more water out of the pool to fix a leak that got much worse over the winter.
    I'm going to be making my own label since you can't seem to buy them!
    Thanks again,
    Terry in NC
    Triad Region of NC
    http://www.shopbot.com.au/ps-hayward-40 ... 78997.html
    You can buy one from that website for 19.00 (free shipping). I just ordered one as well! Hope that helps you!
