Thread: Things going well so far
    My numbers are where I want them except my ph keeps creeping up.Right now the pool calculator tells me to use 84oz of muriatic to bring ph fro 8.4 to 7.8.
    My concern is......I've been adding muriatic acid since getting balanced.Does muriatic acid ever reach a point where water needs to be drained?Like when the cya was too high?
    I just don't want to have to do anymore draining and replacing water if I can avoid it.
    11000 gal L shaped gunite pool with and aggragate plaster
    Pentair cartridge filtration with 1.5 hp pump
    only have 3 returns and one dedicated vacuum line
    manifold to pump is three valve
    22,548
    Re: Things going well so far
    Muriatic acid doesn't build up. It will never reach a point where you need to do anything about it. The most you'll ever have to do is if you add enough to lower your TA too much you may have to throw some baking soda in there. I doubt that'll happen very often though.
    May 2011
    lebanon tn
    370
    its normal for pH to climb some- especially if your TA is a little high; over time you'll reach a balance where it will keep rising but not as fast!
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
