Thread: Translating this Greek
    Ive read a lot of posts on here and the ABC's and I just cant get my brain to wrap around it. LOL Went to the pool store and here is what they said:
    Alkalinity 75
    TC 0.43
    FC 0.40
    cya 8
    They said to add 6lb of Alkalinity Icreaser (Yeah baking soda) and then to add 2 lb of shock.
    This just doesnt seem like that much chlorine to add with my levels being so low. They also said dont worry about the cya being 8 as it will go up with tabs. Should I tell them I am starting BBB? LOL What does a pond of shock translate to bleach? (one of the main things I dont get) is 1lb= to 1gal? The more I think about it the more confused I am getting, but I am not ready to give up yet. Thanks for any help!
    Also can you recycle bleach containers or are they trash?
    16x36 AG 1 1/2hp dying pump with sand filter
    Pool came with house and I am slowly learning the BBB
    22,553
    Re: Translating this Greek
    It all depends on what the "shock" is. there are several items that they call shock so you can't really tell until you read the label. Your best bet is to use Liquid Shock (Just strong bleach) or regular old bleach and use the pool calc to figure out how much. And remember, shock is a process not a product!
    You also need a good test kit of your own.
    I wouldn't raise TA. TA at 75 is fine when using bleach for chlorine. You want TA higher when using trichlor tablets, which is presumably what the store is assuming.
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by ajacob9425
    Most bleach containers are recyclable plastic -- look for the number enclosed in a triangle of arrows at the bottom of the bottle. You could also check to see if your local pool store sells chlorinating liquid at a reasonable price and if they reuse the bottles which is better than recycling them. That's what I do with my local pool store that only charges a small deposit for the bottles and milk-carton-like case that is borrowed in the interim.
