Results 1 to 8 of 8
Thread: Can I remove the pump basket when vacuuming to waste?
    Apr 2010
    Syracuse, NY
    103
    I'm assuming the answer is no, because I never know what's at the bottom of the pool that I can't see. I was asking because there are some leaves that I'm vaccuming, and I keep having to empty the pump basket. I'm going to try and get whatever leaves I can see with the leaf basket.
    20,000 gal., Jacuzzi 250L Laser Sand Filter, inground w/vinyl liner, 1hp pump motor, TF-100 Test Kit.
    crookm11's Avatar
    Jun 2010
    Copperas Cove, Texas
    422
    Re: Can I remove the pump basket when vacuuming to waste?
    You can run the pump without the basket "BUT" I would "NOT" do that if I was vacuuming big particles from the pool. Even though you are bypassing the filter and just going to waste you don't want to create the possablilty of getting anything caught in the pump impeller. Any blockage at the impeller could cause serious damage to the pump or other parts in the system.
    Mark Crook
    13,500 Gallon 24' x 52" Intex Ultra Frame
    Intex Sand Filter and Pump, Intex SWG (All hard PVC plumbed)
    TFTestKit-100---Pool School---The Pool Calculator
    Location: Copperas Cove, Texas --- My Pool Build---Useful Links for Intex Pool Owners
    Not without clogging the impeller - requiring you to pull the pump apart...
    Ironicaly, I was doing a green & clean yesterday... lots of leaves (about 40 gallons of them). And accidentally forgot to put the basket back in. Pump stopped sucking and I look and can't believe I did that. Argh! But with my 1HP "portable" Whisperflo, I'm like a guy in the pit-crew at the Indy 500 - and keep in mind it's only "plumbed" to hoses, making the tear-down much easier...
    ~45Kg Pool with attached Spa, NSP-72 DE, Minmax 400 Heater, Tahoe Blue Pebbletech, Jandy SWG via Aqualink RS-8, The Pool Cleaner (black)
    Pumps: X3 Hybrid Pump (switches to SPA), 2HP Spa (additional, when SPA is on), and a 1HP For Waterfall
    8, 4x12 Solar Panels on the roof of the pool-house (~12' up)
    CAPTAIN JAMES T. KIRK: "I'M SORRY. I CAN'T HEAR YOU OVER THE SOUND OF HOW AWESOME I AM" (Thanks to TFP!)
    Apr 2010
    Syracuse, NY
    103
    Sorry, my bad, brain cramp. I'm using the skim-vac, so the skimmer wll catch the junk.
    If you have something catching the debris, why would you remove the basket? I wouldn't risk it. Tear-aparts on the pad are a pain - and sometimes things get through or past the basket...
    Apr 2010
    Syracuse, NY
    103
    Because I'm an idiot and forgot to put the skimmer basket in the first time.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Don't sweat forgetting it a time or 2 You'll just have to open the pump and clean that basket. It's easier to empty the skimmer basket than the pump basket
    I wish you well with the rest of the cleanup and hope you'll soon have a crystal clear pool
    Luv& Luk
    -Ted
    Quote Originally Posted by edweather
    Ah... Crime already committed (you left that part out.. .). If you didn't get anything in the impeller, then no harm no foul...
    (and as I admitted to my err yesterday, you're not the only idiot here )
