Results 1 to 9 of 9
Thread: Poolvergnuegen "thepoolcleaner" cleaners
    I have a question for those who have experience with the Poolvergnuegen "thepoolcleaner" cleaners.
    Do these cleaners periodically "reverse" automatically, so that if they get stuck on a pool feature they will eventually free themselves?
    38,500 gallon free form pool, Gemstone finish by Burkett's, FNS Plus 60, Pentair Intelliflo Pump #011018, Solar, 12 4x12 panels w/Compool LX220....Soon to be adding automation.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Poolvergnuegen "thepoolcleaner" cleaners
    Yes they do. And they spin around as well.
    It's not perfect, however. If you have unusual features like ramps in the pool and you have an electric safety cover, then it can go up the ramp and get stuck (my 16,000 gallon pool is shown here and here). I have the pressure cleaner (4-wheel) running on a dedicated line with my variable speed pump set to 15 GPM running 2 hours every night.
    susa's Avatar
    Oct 2010
    Deep South
    578
    the getting stuck occurs only if the GPM rate is set too low.
    in my case, I run a cleaning period at 23 GPM and the Poolvergnuegen 2x runs along at brisk pace.
    other Features programming on the IntelliFlow VF run as low as 12 GPM and the cleaner is immobilized, on purpose.
    SW Georgia
    300
    I tried to watch mine clean the pool and it drove me nuts. You have to let it do its business and look at the finished product (a clean pool).
    35K IG Vinyl 20 x 40 self built pool, Hayward Pro Series High-Rate Sand Filter 31" 98gal/min, Hayward TriStar 1.85hp, Hayward 400btu heater, BBB method w/Hypo, Jazz light w/matching fiber optic rope lighting around coping w/syncronized color wheels. Concrete Paver deck.
    Puffin's Avatar
    Jul 2010
    Metro Atlanta, Georgia
    217
    Jasonknox, you've quite a large pool 35k. What do you think of the 4 wheel suction side version? How long does it take to clean your pool?
    19,600 gal, Vinyl, Grecian L, StaRite Dura-Glas 1 HP pump, 3/4hp booster, Pentair Clean and Clear 420 Cartridge filter
    The Pool Cleaner 4x, PoolSkim
    Aug 2010
    Dallas, TX
    4,052
    Yea Puffin, I'll be sad if his works well. I was told my pool was too big for any of their units. They are 1/2 the cost of my robotic cleaner.
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by susa
    I'm not talking about getting stuck in a corner (it never does that) -- I'm talking about going up the ramp and tipping over when it encounters the cover. The speed/flow is irrelevant in this sort of situation, albeit a rare case for most pools. Also, there is a pressure relief valve that opens up if I try and go over 15 GPM anyway and the wheels at 15 GPM are spinning faster than their recommended 12-15 RPM (at the 15 GPM pump setting, I'm getting around 17 RPM with the wheels). Maybe the pressure at the outlet of the dedicated 1.5" line at 15 GPM flow rate is higher than in some other pools or maybe the IntelliFlo is lying to me about the flow rate.
    susa's Avatar
    Oct 2010
    Deep South
    578
    anticipated that situation and installed a very flat cover for the drain, older style cover like in use in the late 80's and system steps over it like any other flat surface.
    my 23 GPM's are also with only a partially open suction line as I pull most water volume from the main drain line and can switch jandy valve to dedicated line but the cleaner starts climbing out of the pool at that point
    SW Georgia
    300
    Quote Originally Posted by Puffin
    It will totally clean my pool in one day or a 10 hour run time. I probably run it every 5 to 7 days depending on how the pool looks. If we have a storm I will usually run it after the storm to get the pool clean. I don't have a leaf catcher so I have to clean out the pump basket more frequently which means I have to be at home.
