Results 1 to 7 of 7
Thread: Some BBB questions
    Jul 2010
    Mickleton, NJ
    229
    Some BBB questions
    I'm going to add bleach for the first time today. The pool is a little less than a year old and I was using pucks before. My FC is at an 8 right now, I was told I should maintain this b/c cya is at 70. I'm planning on adding 1 1/2 quart of 6%. I read to add it infront of the return letting the pump run for at least 20 min. From this point on will I generally be adding bleach on a daily basis? I know to test water and make adjustments as nessasary but as a general rule will it be a daily thing?
    Currently Pooless
    Former Pool:Buster Crabbe resin and steel 30'x15' oval 52" ABG pool Pentair sand dollar filter 1.5 Pentair Dynamo pump13,500 gallons
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Some BBB questions
    Yes, unless you use a feeder like the Liquidator.
    Mar 2011
    Central Florida
    69
    8,700 gallon IG pool (including 2000 gallon spill-over spa), WetEdge Northshore Tahoe (Satin Matrix) finish, Hayward SwimPure Plus T-15, Jandy JXi 260k propane heater, Jandy FloPro 1.5HP 2 speed pump, Jandy CS 150 cartridge filter, TF-100, Borates added, BBB is the way for me!
    SW Georgia
    300
    yes, I test daily and add chlorine daily if needed.
    35K IG Vinyl 20 x 40 self built pool, Hayward Pro Series High-Rate Sand Filter 31" 98gal/min, Hayward TriStar 1.85hp, Hayward 400btu heater, BBB method w/Hypo, Jazz light w/matching fiber optic rope lighting around coping w/syncronized color wheels. Concrete Paver deck.
    Apr 2010
    East KY
    51
    I do test daily (well most of the time) , but usualy I only need to add bleach every other day. I add enough to get to the max of my range according to the cya chart in Pool School, then let it drift down to the low end before I add. If I have a heavy bather load I usualy have to add more often.
    I installed the Liquidator Sunday, so I'm hoping to do less daily dosing this season.
    11400 Gallon AG 22ft
    Hayward Sand Filter
    1 HP Hayward XL Pump
    Liquidator 3/8" upgrade, Hayward Needle Valve
    Useful Links: Turning Your Green Swamp Back into a Sparkling Oasis, Pool School, The Pool Calculator
    May 2011
    lebanon tn
    370
    I add 1.4 gal (1 jug) of bleach when I hit the low end (min) FC, which right now holds 3-4 days...
    Test each day at dusk, add if min don't add if above min...
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
    Mar 2007
    San Rafael, CA USA
    12,082
    I add chlorine twice a week, but I have a mostly opaque electric safety cover that keeps chlorine usage down to 1 ppm FC (or a little less) per day in spite of the pool being used for 45-90 minutes every day and temps at 85-90ยบF. So I usually go from around 6 ppm FC to 3 ppm FC and back again with 40 ppm CYA.
