Results 1 to 18 of 18
Thread: zeobrite or sand???
    Apr 2010
    St Louis MO
    14
    zeobrite or sand???
    So, I finally found a pool service that is coming out tomorrow to replace the broken lateral for me... whew! They suggested and I figured it was a good idea to go ahead and change the sand since I bought the house last year and don't know when it was last changed and since they're already gonna be "in there" might as well.
    He suggested using Zeobrite and said that even though it's more expensive ... you don't have to replace it as often as you do sand so it works out in the long run. I told him okay but then later googled and found that 50lb bags of sand are less than $10 and I need 3 bags of zeobrite @ $25/bag plus the website says it lasts "just as long" as sand... nothing about longer.
    So any thoughts on the benefits of paying so much more for this stuff or should I just have them replace with sand?
    Kelly from St. Louis
    27ft AG approx 18,000 gals / Jacuzzi Laser Sand filter
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: zeobrite or sand???
    I started selling "zeobest" a few years ago but then someone mentioned that some zeos are of lesser quality/hardness and can be crushed into a cement like block. This has never happened to me but it worried me that it could happen; so I switched back to sand (MysticWhite). I never really noticed a difference between the sand and zeobest filters I've sold (in terms of water quality).
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Cherie's Avatar
    Jul 2008
    Wylie, Texas
    506
    We're beginning our fourth season with Zeo(don't know if it's Bright or Best) and we've been very pleased with it. Supposedly, it filters as well as DE. It doesn't filter out the pollen. But we use skimmer socks, which help tremendously. We also use an Aquabot Turbo, which filters stuff down to .2 microns.
    32x16 buried Doughboy, 4' shallow - 7' deep
    Pentair Dynamo 1 hp, 2-speed - Pentair 150# SD40 w/zeolite (75#)
    One skimmer/two returns/Aquabot Turbo T2
    30,403
    It's difficult to find consensus on the forum but my personal experience is that sand simply doesn't wear out. Mine is 7 years old and I plan to NEVER change it.
    Zeo has mixed reviews but I don't recall anything definitive on the forum over the years that would indicate it is any better and it certainly CAN be worse if it's not installed properly.
    The prime tenant of BBB is not putting anything into your pool you don't need. I'm not sure if Zeo falls into that category completely but I think it comes pretty close.
    Zeo seems to be risk prone. When it works it works very well, with some people positively raving about it, but sometimes it has problems and causes the water to get cloudy all the time or clumps up.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    We called Hayward about this and asked what they recommend and basically they said their filters are designed for use with sand. They didn't say you can't use it but it's just not technically supported. Oh well, sand is keeping the pools clear and I definitely do not want to brick a filter; even if it's a small chance.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    Jul 2009
    London and France
    574
    I used to think the same but my ideas were completely altered when I saw a commercial sand cleaning operation. Sand has been around for millions of years and it does not get worn out anymore by the occasional backwash procedure.
    That said there are occasions when it has to be changed for instance hard water calcium build up takes too long to clean up so it's not economic. Indeed it may not be economic to clean in terms of time compared to the relative low cost of replacement but it doesn't wear out.
    I saw 10 year old sand from a commercial pool filter which was in poor condition. Once it had been cleaned I viewed it under a microscope against new sand and you couldn't tell the difference. I have used the same technique on a domestic filter and the crud we removed was amazing.
    Some zeo... is too soft so as Jason says inconsistant results, I have some Australian zeo which isn't like the ones I have seen before and is suposedly very hard so stands up well for a lond life but with any fine filter it will clog and the millions of tiny holes would be very difficult to clean despite what the marketeers say.
    Lots of hiding places for bacteria in there!
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    I bought zeobrite simply because i couldn't find any sand!! The two local pool stores promised to ship some in for me. I waited 3 weeks and still no sand. So with our summer being short enough as it is, I decided to get the zeobrite. It works fine, no problems other than I didn't backwash enough at startup but that's my own fault. That being said, I would have bought sand if it had been available. I read a trememdous amount of material and I believe that zeobrite is just not worth the extra cost. There are POSSIBLE risks, and I see no need to take those risks if silica sand will filter just as good for cheaper.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Jul 2009
    London and France
    574
    Quote Originally Posted by GreatCanadian
    Silica sand will not filter just as good as zeolites, silica sand is cheaper and may still be all that's needed for domestic pools though.
    It does worry me about people not backwashing new media thoroughly, silica dust is nasty stuff and zeolites have more free silica than sand I believe.
    Jul 2011
    844
    I do believe that after sand gets a little dirty, it will filter just as good....just a belief, not a fact! However I do agree with you about not backwashing enough. I "followed instructions" which said 2 minutes should be enough. Not even close!! But it all cleared out in the end.
    Bestway SWG
    Sep 2012
    Gardiner, ME
    165
    Pool store told me today and i quote "You'll be much happier with this product than sand, i hardly sell any sand... it's the start of the season, I have 5 pallets of zeo and 1 pallet of sand... gave me 20% off... 50 lbs for my 100lb filter was 47$... sand would have cost me 60$ minus 20%...
    24 ft Sharkline Matrix AG
    Waterway 1HP 2SPD Sand Filter 100lb sand capacity, using 50lb of ZeoSand
    TAYLOR K-2006 test kit.
    Installed Spring 2013
    16x16 Deck Going up Soon.
    That is a wonderful marketing trick. Leslie's, which is not known for low prices, sells filter sand for $12 for 50 lbs. By marking up their sand ridiculously high they made Zeo look like a good price, when it is not.
    Sep 2012
    Gardiner, ME
    165
    His sand was still cheaper than pool supply world by almost 20$ a bag.....
    Where do you live? Amazon will sell you 50 lbs of filter sand for $36, including delivery anywhere in the continental US. Typical retail price in the US is around $8 to $15 for 50 lbs if purchased locally.
    Sep 2012
    Gardiner, ME
    165
    I used ZeoCrap this year... filtered great for the first month... back washed WEEKLY!!!!!! and towards the end of the summer it wasnt filtering anything... SAND NEXT YEAR!
    May 2013
    North East Ohio
    959
    SAND - my PB "forced" me to use GLASS MEDIA and it is 100% terrible...doesn't filter anything. Stick with Sand!
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    Sep 2012
    Gardiner, ME
    165
    I hear sand with a splash of de works great
    May 2014
    baltimore, md
    1
    I have been using the same Zeobrite material in my sand filter for 5 years now (5 summers, as i'm in the northeast.) I made several changes at the same time, so I'm not sure which provided the most benefit, but my 27K gallon pool has been trouble free since then. i converted to salt water chlorine generator, zeobrite in the filter and new pump. The pool is almost 40 years old and has never been this clear and trouble free. I hope I'm not jinxing myself here
    Quote Originally Posted by kellyiscoolbythepool View Post
