Results 1 to 12 of 12
Thread: help
    help
    i have read pool school twice kinda understand but dont understand pool calculator at all
    16\32 30,000 gallon inground pool triton II sand filter 3 h.p pump hayward chrlorinator
    Re: help
    oh by the way i was trying to figure out how to do the bbb thing instead of high priced pool chemicals
    SW Georgia
    300
    Re: help
    I use BBB and do not use the pool calculator. I have tinkered with it some but do not use it.
    35K IG Vinyl 20 x 40 self built pool, Hayward Pro Series High-Rate Sand Filter 31" 98gal/min, Hayward TriStar 1.85hp, Hayward 400btu heater, BBB method w/Hypo, Jazz light w/matching fiber optic rope lighting around coping w/syncronized color wheels. Concrete Paver deck.
    30,415
    Re: help
    jdt,
    Do you have a question? The answers are almost all in pool school and we'll help you through it one subject at a time
    Re: help
    ok jason iam ready to tinker with the bbb but i need some rough ideas on how much bleach and other stuff to to start with my pool is 16x32 in ground 12 foot deep end with 4 foot in shallow
    Jul 2010
    Mickleton, NJ
    229
    Re: help
    I understand where you are coming from, I am also new at this and becoming BBB, keep reading pool school and I also just checked the BBB forum section, some of my questions were answered there. You can also, do a search as well. I think we will need to know your current levels of FC and CYA to tell you how much bleach is nessasary, can anyone else chime in to confirm this? I don't want to give bum advice.
    Currently Pooless
    Former Pool:Buster Crabbe resin and steel 30'x15' oval 52" ABG pool Pentair sand dollar filter 1.5 Pentair Dynamo pump13,500 gallons
    Re: help
    Have you tried reading the article on the Pool Calulator? It goes through the basics step by step.
    SW Georgia
    300
    Re: help
    jdt - Do you have a good test kit like the ones referenced in these forums? I have the TF-100. If so what are your current numbers and how many gallons does your pool hold? If you do not have a quality test kit you need to get one as they are the only way to truly monitor how your pool acts once chemicals are introduced. Bleach comes in differenct Percentages of Chlorine. The typical percentage seems to be 6% but some other off brands can have a lesser percentage. I use liquid chlorine from pinch a penny that is 10-1/2%. These different percentages will play a factor in how much of a product is put into the pool. It may seem overwhelming at first but once you get on a routine/plan it will all start to make sense.
    22,548
    Re: help
    jdt - Lets tackle this one step at a time.
    Do you have a good test kit?
    If so what are your test results? If not, get a set of test results from the pool store (until you can get a good test kit) and post them.
    Here's what we need,
    pH
    FC
    CC
    TA
    CH
    CYA (stabilizer)
    Once we know those things we can walk you through using the Pool Calc and get you on your way.
    Re: help
    ok been testing my water ph is good been putting clorine tabs in skimmer basket but tests saying my clorine is is still to low dont know how much bleach to put in
    Aug 2010
    Dallas, TX
    4,052
    Re: help
    To estimate chlorine you need:
    Current free chlorine ppm:
    Current Cyanuric Acid:
    Pool Volume:
    Fill those in and we can go from there, but it would be best if you'd fill all Bama's blanks in.
    BTW, tablets are very slow to release chlorine and add to CYA.
    ThePoolNinja's Avatar
    Apr 2011
    Southern California
    61
    Re: help
    Be careful putting trichlor tablets in your skimmer basket. They're acidic and when your system turns off, they sit and over time can strip metals and stain your pool. It's better to put tabs in a floater on a leash, tied close to a return line and away from steps.
