Results 1 to 15 of 15
Thread: Need advice on my numbers
    The pool was finished in the fall, filled and closed by pool company. The pool company opened it a month ago but it has been cold and rainy in Chicago area. Just trying now to get it dialed in.
    Temp - 64
    FC - 16.5 Pool company had Intellichlor set to 60%, I just dropped it down to 20% - reading all green
    PH - 7.4
    TA - 200
    CYA - 33
    The sides of the pool feels a little rough, looks a bit cloudy, but no smells.
    Thanks for any input
    20x40 IG, 35,900 gallon, Vinyl, Pentair Tagelus Sand Filter, Pentair Master Temp Heater, Pentair SuperFlo Pump, Intellichlor SWG, Eclipse Auto Cover, Magic Stream Deck Jets
    Re: Need advice on my numbers
    Welcome to TFP!
    With a SWG you want CYA around 70 to 80.
    With TA around 200 you need to keep an eye on the PH, it will tend to go up. Any time PH goes up to 7.8 you shoudl lower it back down to 7.2.
    Thanks for the input. I noticed that I need to add additional pool info in my signature.
    They added stabilizer when they opened it but must not have used enough. Do I buy the stabilizer at my pool store?
    Stabilizer/CYA is only sold at pool stores and the pool departments of some of the big box stores like WalMart, Home Depot, Lowes, and so on. Often the big box stores have better prices, but they are not consistent about having things in stock. Pool stores will always have it.
    Thanks. I will get that rolloing tomorrow.
    Should I continue with the process to bring down the TA through lowering ph and aeration as described in the posts, while I am bringing th CYA up?
    Aslo wondering if the FC will fall with the SWG setting and as the temp rises. My CC is 0.
    You will probably want to get going on the entire lowering TA process, but since the water is cold the PH probably won't go up quite as quickly as it otherwise would and you might be able to get away with a more leisurely approach.
    As the CYA level comes up you will be able to turn down the SWG percentage. On the other hand as the water gets warmer you will need to turn up the SWG percentage.
    Counts as of noon today
    Water Temp - 66
    FC - 9
    PH - 8.1
    TA - 219
    Hardness - 309
    Minerals - 3600
    Borates - 11
    Intellichlor set to 20%, fountains running all day for aeration
    Stabilizer - Pool store says 8.5 pounds, pool calculator said 10lbs, I am thinking 6 lbs to start?
    Should I do the stabilizer before adding the muratic acid?
    When can the pool be used after adding the stabilizer?
    Thanks
    Get the PH down right away. Try to keep the PH below 8.0 at all times.
    Go ahead and add some stabilizer. You can actually add stabilizer and lower PH in either order, PH is just more important. Using 6 lbs for now is fine. Wait a week, test again, and adjust from there.
    You can swim any time except for 30 minutes right during and after adding the acid to lower PH.
    Here is an update.
    Water temp - 73
    FC - 10
    CC - 0
    pH - 7
    TA - 140
    CYA - 40
    SWG - set at 20%
    Pump running 24/7, jets running 16 hours per day
    Added 4 gallon of Muratic Acid early evening 5/10
    Added 6 lbs stabilizer 5/11 - 6:00 am
    Looks like progress but I am along way from being balanced so I am not sure what to do next.
    Thanks
    That looks much better.
    I expect the PH will tend to go up fairly quickly. You can either lower the PH to 7.2 every time it gets up to 7.8; until TA comes down to 70, or if PH rises so quickly that it is annoying, you can do the lowering TA process described in Pool School.
    The other thing to watch is where FC settles down with the SWG on 20%. The best thing to do is to wait a couple of days and then start measuring FC in the evenings for several days and watch to see where it settles down. If FC gets too low you will need to turn the SWG percentage up a notch.
    Great - Thanks.
    Will the CYA continue to rise over the next few days from the stabilizer I added or will I need to add a few more pounds of stabiler to get it to 60-70?
    If you added granular CYA, it will take up to a week to fully dissolve and all show up. Liquid CYA takes a few hours to fully mix in.
    Back with some updated numbers. I was out of town for a few days.
    FC - 9 (I have never added any chlorine/bleach)
    CC - 0
    pH - 7.2
    TA - 130
    CYA - 60 (added two more pounds of stabilizer on week ago)
    SWG - running 20% - readings are all good
    Pump running 16 hours a day
    Water Temp - 77 (have had the heater on sporatically)
    Water looks clear, feels good on the skin, sides and bottom or smooth
    Temps in my area will in the highs of only 60 degrees and lows of 40 at night for the next 5 days
    Thanks
    You are looking fairly good.
    If you have problems with the PH drifting up, allow the TA to go down by simply lower the PH back to 7.2 every time it gets up to 7.8. If the PH drifts up very quickly you can speed up the process of lowering TA by following the directions on lowering TA in Pool School.
    Pentair Intellichlor Issues
    The red light has been on in my Intellichlor SWG for 5 days. It indicates low salt so I added 40 lbs two days ago thinking this would help - no help. I turned it off and on and it is still on. The manual says that this indicates low minerals and that when it is Red it is not working. My pool company is not very responsive so I always want to fix things myself
    FC - 5
    PH - 7.5
    CYA - 67
    TA - 166
    Minerals - 2800
    Any advice would be great.
    Thanks
