Thread: What do I do? It settled on me!!!!
    Oct 2010
    Parker County, Texas
    27
    Got my Intex 15x4 set back up after fixing some issues with the pad. Finally almost full of water and I'm messing with the pump and new plumbing when I hear a leg start sinking!!!!
    No I didn't put anything under the foot since I had it on packed decomposed granite (hard as a rock) but I guess in all my moving of pad sand under the liner about an inch of it ended up on top of part of the granite because that is where 2 adjacent legs settled to. 1 inch below the sand top to the granite.
    Problem is that particular section contains my new thru wall skimmer. It now doesn't have enough air space if the pool is filled to the correct level. I need to lift those two legs and put a small block beneath. I have a tractor with a bucket and chain, could I get an inch of lift out of it long enough to slide a block underneath or am I going to have to drain my pool?! Any other suggestions?
    Intex 16x48" Easy Set metal frame pool filtered by a Hayward 1.5hp PowerFlo Matrix pump with Pro series sand filter. It's a work in progress so my saltwater system and complete PVC plumbing is in the future.
    LED pool light for nighttime fun!
    crookm11's Avatar
    Jun 2010
    Copperas Cove, Texas
    422
    Re: What do I do? It settled on me!!!!
    Hi
    You don't have to drain your pool to make the adjustment you need. I had to adjust a couple legs on mine and mine was fully filled. You need to make sure the legs are braced because as soon as you lift them off the ground they will push out from the force of the water. Take a 2 foot long 2x4 and make a point on one end of it. Pound the newly made stake into the ground (at least a foot deep) about the width of a 2x4 away from the leg. Now take another 2x4 and put it between the leg and the stake. Should be a tight fit. Now get a floor jack and another 2x4. The 2x4 should be almost as tall as the pool. Take the floor jack and put it right next to the side of the leg you want to lift and stand the 2x4 on the floor jack and set it just under the "T" portion of the leg as close to the center of the "T" as possible. Once it is set use the floor jack to lift the pool. The 2x4 between the leg and the stake will keep the leg in when the leg lifts off the ground. Put whatever you need under the leg and set the pool back down.
    Use the same system for any leg you need to adjust. Hope this helps.
    Mark Crook
    13,500 Gallon 24' x 52" Intex Ultra Frame
    Intex Sand Filter and Pump, Intex SWG (All hard PVC plumbed)
    TFTestKit-100---Pool School---The Pool Calculator
    Location: Copperas Cove, Texas --- My Pool Build---Useful Links for Intex Pool Owners
    Oct 2010
    27
    Wow, I kinda wondered if something like that would work! What you explained seems a LOT safer than what I was planning with the tractor bucket and chain! I will have to do this sometime the next few days!
    Oct 2010
    27
    Umm, out of curiosity, how BIG of a floor jack did you use (as far as weight rating)? I have a bottle jack that is good for 6 tons and a floor jack that is good for 4 or 6 tons, would that be sufficient for 1.5" of lift for one section of the pool?
    crookm11's Avatar
    Jun 2010
    422
    Either one will be fine.
    Mark Crook
