Results 1 to 7 of 7
Thread: Initial, disturbing TF-100 measurements...
    Oct 2010
    Eastern TN
    172
    My PB is supposed to balance pool. Still waiting for concrete to finish job. I haven't been home when he and his guys have added chemicals but I got this today:
    temp 86
    ph >8.2
    CYA 0
    CH 320
    TA 240
    Chlorine 0
    My salt generator displays red too low salt. They left me a bag of salt to add if light is on tomorrow. They added acid once but pH is still too high. I'm particularly concerned about TA level. Do I have to dump water from pool? The initial fill water had a lot of iron and I was told that by shocking pool several times that the iron was removed. I have no way of measuring iron. Can this be throwing other tests off?
    Water looks great but boy am I far away from the recommended levels posted here. What to do?
    Plaster pool inground 22,000 gallons with spa. Pentair Intelliflo, IC40 salt generator, WiFi control/Easy Touch.
    Hayward 1.5 HP pump on 750 gallon spa. Sand filters. Auto chlorinator on spa. Auto water level. Dolphin M500. TF100 XL with Speed Stir. Apera Instruments AI311 PH60 Premium Waterproof pH Pocket Tester
    22,542
    Re: Initial, disturbing TF-100 measurements...
    Just by adjusting the pH down with acid whenever it gets high will lower the TA. Don't worry about the TA worry about the pH and the TA will take care of itself. You really need to get some chlorine in there. The sooner the better. Add enough to get to 3ppm. Then you'll need some CYA in there. I don't know how much of Pool School you've read and understand but keep reading.
    Oct 2010
    Eastern TN
    172
    The TA going down with pH correction was what I was really wondering about. We are adding salt to pool to get SWG running and I will add bleach to get chlorine levels up.
    Oct 2010
    Eastern TN
    172
    Stabilizer arriving today. I have shocked and will get chlorine level corrected after stabilized.
    My pH is reading 8.2 plus with my new kit. I have added more than 3x the acid the pool calculator said is needed to get to 7.6. I'm now adding 6 oz at a time trying to get pH down using 31.45% muriatic acid. Is this the proper procedure? How much more acid should I reasonably expect to add?
    The PH test will report any level above 8.2 as if it was 8.2, so you actually level might have been quite high. Also, with TA around 240 it can take a really large amount of acid to change the PH. You have the correct procedure, though you could easily add 16 oz at a time instead of 6 oz as long as TA remains above 200.
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    With respect to your SWG, make sure you test the water to be in range with your SWG. I tested mine (Intellichlor) several times and was in the optimum range even though my SWG indicated LOW salt. Had to calibrate the SWG to get it to know where I was with the real measurments of salt.
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    Oct 2010
    Eastern TN
    172
    Quote Originally Posted by XsAllOverIt
    Great advice. Wish I had gotten the salt test strips with my kit...
