Results 1 to 15 of 15
Thread: SWG having issues with making FC
    Hurricane Gio's Avatar
    Apr 2010
    Coral Gables, FL
    197
    I have a Aqua-rite T-15 SWG on my pool. All last year I ran the cell at 15-20% to keep FC around 4-5.
    This year after running a few days at 40%, my FC is only around 3-4. The ump runs 20hrs a day with 6 hrs on High speed. I see the bubbles in the water, but I can't get the FC to get higher. I have my solar cover on the pool.
    the water is in balance.
    FC 3-4
    PH 7.8
    TA 75
    Borates 50
    Salt 4300
    CYA 70
    is they cell going bad after 1 yr and a few months? Its clean and all wires seem fine. Again, its making chlorine as I can see the bubbles.
    8,000 Gal, 11 x 26.8ft Shotcrete Pool with "Cool Blue" Diamond Brite by ESSIG Pools with Artistic Pavers Deck
    Goldine AQL-PLUS w/Aqua Pod, Aqua-Rite T-CELL-15 SWG, Pentair WhisperFlo High Performance 1.5HP, 2 speed pump, Pentair IntelliBrite,
    Pentair 100sqft Cartridge Filter, 6 Pool returns, Skimmer and 2 Anti-Vortex Main Drains
    Pool's completed build 2/2010
    Re: SWG having issues with making FC
    You should do an overnight FC loss test to see if you have the beginnings of an algae problem.
    Also, what is the water temperature? If the water is below 60 degrees the cell might be having problems because of the cold water.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Is your Salt reading form the cell or from a test strip? A strip would be better.
    If the salt is in line, another possibility is a sem-supressed algae bloom that might be cured by shocking the pool. Is the water clear?
    If in doubt, an Overnight FC Loss Test might be in order.
    Apr 2010
    Coral Gables, FL
    197
    The water is 88 degrees and its crystal clear!
    SW Indiana
    9,199
    Quote Originally Posted by Hurricane Gio
    Apr 2010
    Coral Gables, FL
    197
    Quote Originally Posted by JohnT
    from the cell. I screwed up the salt test last week. I will test the salt again. I I dumped 80 is the last month or so.
    Apr 2010
    Coral Gables, FL
    197
    huh?
    Apr 2010
    Coral Gables, FL
    197
    Ok, test strips shows about 4680ppm on the salt
    Dec 2009
    Central Massachusetts
    2,690
    [quote=Hurricane Gio]
    Quote Originally Posted by "Hurricane Gio":1vufiiz6
    huh?[/quote:1vufiiz6]
    I think John is lamenting the temperature of his own water in indiana compared to yours in south florida.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    SW Indiana
    9,199
    Quote Originally Posted by "Hurricane Gio":2fplfrat
    huh?[/quote:2fplfrat]
    I'm jealous! I'm at 68 with the solar cranking! It's been a very cool spring.
    Apr 2010
    Coral Gables, FL
    197
    LMAO! hey, its Florida! The water will drop to the low 80's without the cover and its too cold to swim
    Aug 2010
    Dallas, TX
    4,052
    It is 91 here in Dallas today, and my water temp is 74. It's all the rain we've had I think! Didn't stop me from getting in the pool this weekend
    Oct 2010
    Georgia
    317
    We need to clarify your water test results.
    If CA=70 is Calcium hardness then we need to know the CYA.
    A low CYA level will reduce chlorine residual and the output of the SWCG will need to be set to a higher level.
    PSG
    poolschoolgrad
    20x40 free-form IG vinyl, 1hp Hayward superpump, Hayward pro grid DE filter, Raypak heatpump, Goldline Aquarite SWCG, Polaris 280 with booster, and tested using a Taylor K2006.
    Apr 2010
    Coral Gables, FL
    197
    Quote Originally Posted by Poolschoolgrad
    PSG
    Sorry, that was CYA
    Oct 2010
    Georgia
    317
    Other things to check:
    Clean the cell as per the manufacturers recommendations.
    Even minor scalings can reduce chlorine output.
    http://www.haywardcanada.com/products/m ... ual345.pdf
    See page 9.
    If algae is beginning, set the output to 100% for 48 hours, then back to 40% for 48 hours.
    Please post your results.
    Thanks
    PSG
    poolschoolgrad
