Results 1 to 11 of 11
Thread: Tested for the 2nd time, what is next?
    Jul 2010
    Mickleton, NJ
    229
    PH= 7.2
    FC= 8.5 (down from 27 about 10 days ago)
    CC= .25
    TC= 8.75
    TA= 80 (it was pink, should I have kept adding until the solution was really red?)
    CYA=70
    I haven't added any chemicals to the pool since I pulled the pucks out with the last test. Should I add anything yet and if so what, I have the pool calculator app but am a little confused. I'm ready to ditch the pucks and go with bleach but I'm not sure how much and how often to add it.
    Currently Pooless
    Former Pool:Buster Crabbe resin and steel 30'x15' oval 52" ABG pool Pentair sand dollar filter 1.5 Pentair Dynamo pump13,500 gallons
    22,553
    Re: Tested for the 2nd time, what is next?
    When testing you should drop drops until the color stops changing and then don't count the drop(s) that didn't make the color change.
    The only way to know how much to add is by testing and using the Pool Calc. You enter your target numbers in the target column and then you test and enter those numbers in the now column and it'll tell you how much bleach to add. You should test FC and pH daily and the rest monthly. Once your confident with your pool you can use the OTO test daily and the FAS-DPD test weekly.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    You'll want to stop using pucks now. CYA at 70 is on the very high end for a manually chlorinated pool. Your current FC level of 8 is pefect for CYA at 70. My advice is to stop using pucks and add enough bleach each evening to maintain FC at 8ppm. Otherwise your numbers look pretty good.
    Assuming you'll burn around 2ppm of FC per day, you'll need to add about 1.5quarts of 6% bleach per day...adjust to taste
    I'm assuming your pool is somewhere around 12-13K gallons
    Jul 2010
    Mickleton, NJ
    229
    Thanks for the replies (yes, I'm done with pucks). I went back to pool school again but I didn't see it mentioned how to add bleach to the pool, does it go into the skimmer? Do I dilute it?
    Currently Pooless
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    We advise pouring it slowly in front of your return jet, while the pump is running and letting the pump run at least another 15-20 mins to mix things up
    Jul 2010
    Mickleton, NJ
    229
    Ok, thanks so much!
    Currently Pooless
    Jul 2010
    Mickleton, NJ
    229
    WTH? So after reading the posts on this thread, and assuming 2 ppm drop per day I added bleach for the first time 6% clorox on Tuesday the 10th, (on May 8th it was FC=8). I was trying to maintain the FC=8 as suggested. It was suggested to put in 1.5 quarts, I put in 1qt just to be a little conservative. The pool looks crystal clear, I've been testing the last few nights using the simple yellow drop test. It has matched the 5/10. So today I wanted a more accurate reading and did the FC, CC and TC. FC is 11, CC is 0 and TC 11. I guess it is good that CC is not zero but why is FC so high?
    Currently Pooless
    22,553
    Your first mistake was assuming you would lose 2ppm per day. The only way to know how much you lose is to test often enough to know your pool.
    So now you can cut down on the amount of chlorine you add each day.
    I tested with the FAS-DPD every day for about 2 months until I learned my pool. I now know what a cloudy day, a pool party, A sunny day, A thunderstorm, etc. will do to my pool.
    Nov 2010
    Calera, Al
    271
    Quote Originally Posted by melissab
    A 2ppm loss per day is a guestimation... Each pool has it's own character or personality. Your pool might loose less than 2ppm due to high cya or less direct sunlight or other circumstances
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    Jul 2010
    Mickleton, NJ
    229
    That is what I figure now. I'll just use the FAS-DPD everyday until I see how much chlorine I will lose daily.
    Currently Pooless
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    A good rule of thumb is to test before you add. The OTO TC test is good for pressence, but most of us can't tell 1ppm of TC from 5ppm of TC.
