Thread: Starting to balance the new pool
    Jan 2011
    Riverside, CA
    352
    I've had water in the pool for a little over 30 days now. I'm ready to start some real work on the chemicals. My TF-100 kit arrived about a week ago, I have not had a chance to play with it yet.
    Pebble Plaster installed on 4/1/11. The equipment is listed at the bottom. I have a Liquidator installed, but not adding any chlorine (waiting for 30 days). In the mean time, I have been using some liquid chlorine and mostly BioGuard Silk Tablets in the floaters. Water is clear and I don't see anything wrong with it at this time.
    I'm going to start with these suggested levels for the Pool Calculator:
    Plaster with Bleach
    FC 3-7
    pH 7.5-7.8
    TA 70-90+
    CH 250-350
    CYA 30-50
    CYA (Stabilizer)
    20 min 2 target 3 shock 10
    30 min 2 target 4 shock 12
    40 min 3 target 5 shock 16
    Since CYA is constantly increasing, should I aim for 30 instead of 40?
    Liquid Chlorine is supposed to raise the pH, so should I leave it at 7.4 to start?
    My last 5 test results are below. Is this the best plan?
    Adjust CYA to 30...then
    Adjust FC to 4...then
    Adjust pH if necessary
    TA looks to be within the range. The BioGuard guy wants be to bring it up to 125-150
    Not much I can do about the CH, we have hard water here. We might install a water softener for the house. Does anyone use the house softened water in the pool? I know that I can't go too low on the CH.
    Thanks
    40x20 Free Form IG Pool (aprox 29,000 Gal, 140 Perimeter, depth 3'6"-7', Baja Shelf, 8x8 Free Form Spa) - Gunite Shell, Pebble Plaster Finish, Poured Concrete Coping - 3 Deep Heat Returns - Jandy LXi400 Gas Heater (400,000 Btu) - Jandy Variable Speed Pump JEP 2.0 - Jandy CL 600 Filter - HASA Liquidator - Jandy PDA 6 w/ Remote - 4x Jandy WaterColors Pool LEDs - 48" Gas Fire Pit - 6x Gas Tiki Torches - 12'x15' U-shaped BBQ Island (Firemagic Equipment)
    http://www.troublefreepool.com/new-p...ca-t28413.html
    May 2011
    lebanon tn
    370
    Re: Starting to balance the new pool
    I think the floaters added CYA, I wouldn't add anymore until those readings settle out after you quit using the pucks...
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
    Quote Originally Posted by Nightmare
    CYA only increases if you use trichlor or dichlor (ie the Liquid Silk sticks). If you are using bleach, CYA goes down very slowly. If you are switching to bleach.liquid chlorine soon it is best to aim for a CYA of 50, and then it will drift down slowly and still be able 30 by the end of the season.
    Liquid chlorine does not raise the PH. PH tends to drift up because of TA. The higher the TA and the more aeration you have the more PH drifts up. In any case, if you are going to stop using trichlor soon, leave your PH at 7.4 and seeing how it behaves is a good idea.
    You only want to raise TA up to 125-150 if you are using trichlor, which is acidic. Depending on how long you are going to continue to use the liquid silk sticks you may or may not want to raise TA.
    Using the water softener for topping off the pool is fine, just keep an eye on CH and don't use the water softener if CH gets too low.
    Jan 2011
    Riverside, CA
    352
    Ok, it's been a little busy and I have not had a chance to get the Liquidator up and running.
    I added the sock of CYA and the level is good. I tested and then took a sample to the local Bio-Guard store the next day.
    Home Results 5/24:
    Ph - 7.6-7.7
    Ch- 1-2
    CYA- 45 or maybe 55 (I'll look for a thread on how to eyeball the CYA dot)
    I added a gallon of Chlorine (12.5%) to the pool on 5/24
    I took my sample to the store on 5/25
    CYA - 49
    Ch - 5
    pH - 7.8 ***She changed the number in the computer based on the second test she ran on standard test kit. Is this normal? Or did she change this number higher to make up for the 17 lbs of Balance Pack 100 they want me to put in the pool?
    TA - 96
    Adjustet TA - 81
    CH 297
    I tested the chlorine again today and I read it as about 2-3 (nowhere near the 5 they told me the day before). The pH is between 7.6 and 7.8, but not a full 7.8.
    I just added about a Quart of Acid to bring down the pH. I'm going to wash out the Liquidator (looks a little dirty sitting full of water for 2 months) and add some Chlorine.
