Results 1 to 10 of 10
Thread: ? about water depth of Intex metal frame pool 48"
    Hi
    I was wondering if anyone knows what the minimum depth a 48" pool can be? I'm assuming that anything over the filter intake would be fine...is this true? Does anyone know the depth of the filter intake? I can actually buy the 48" pool for cheaper than the 42" pool, but I really want the water to be around 36 to 38 inches, until my kids grow a little taller. Thank you in advance for your reply!!
    Intex 15X48 metal frame pool
    May 2011
    lebanon tn
    370
    Re: ? about water depth of Intex metal frame pool 48"
    The INTEX skimmer is adjustable height, mine I think would go down as low as about 40 in but not sure (it's been a couple of years) but would be easy enough to make an extension lower if necessary...
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
    crookm11's Avatar
    Jun 2010
    Copperas Cove, Texas
    422
    Hi mapoolgirl! Welcome to TFP.
    The water height should be just above the suction line and you will be fine. You don't want to let the pump suck in any air because it could cause the pump to over heat and die. Just like what madwil said if you have to go lower than what the skimmer will allow then an extension will need to be made.
    Mark Crook
    13,500 Gallon 24' x 52" Intex Ultra Frame
    Intex Sand Filter and Pump, Intex SWG (All hard PVC plumbed)
    TFTestKit-100---Pool School---The Pool Calculator
    Location: Copperas Cove, Texas --- My Pool Build---Useful Links for Intex Pool Owners
    Thanks for the replies! Do you think it would be better to get the 48" pool and keep it around 36 inches or get the 42" and have that at 36"? I can get the 42" for $300 or the 48" for $250. 36" is the perfect height for my kids right now...but I don't know if I would be better off in the future to have a pool that gets deeper than 36"( that's the max depth of the 42" pool) What do you think?
    May 2011
    lebanon tn
    370
    I used my INTEX for 4-5 years, replaced the liner once due to ice damage...
    So, with growing kids, I'd get the 48 and just keep the water level low until you're comfortable with kids height and water abilities
    Jun 2017
    Huntsville, AL
    7
    mapoolgirl, did you end up choosing the 48" depth? Were you happy with your decision? Any issues only filling to 36"?
    I'm in the same situation, trying to choose.
    dorgan's Avatar
    Apr 2017
    Rockledge, FL
    82
    Intex does make a 12' x 30" pool. I have 5 year old girls who love it and even my wife and I are able to get in and enjoy from time to time.
    Pool: Intex Above Ground Metal Frame 12' x 30"
    Pool Volume: 1700 Gallons
    Pump: Krystal Clear 2500 GPH Pump
    Mar 2018
    East Northport, NY
    14
    We are also looking at Intex 42" versus 48" height. We would need to underfill the 48" pool such that water depth would be max of 37". Just wanted to follow up on this message to see whether anyone has done this with success (or encountered problems)?
    Thanks!
    No pool yet! Considering Intex square frame (either 14 x 14 x 42" or 16 x 16 x 48") with upgrade to sand filter and saltwater system.
    Feb 2018
    bixby
    1
    I left my 48" deep up over winter. Lowered the water to below the return. Plugged the intakes. I didn't measure but I assume it's around 36-37. I can measure later. Of course we haven't been swimming but structurally it seems fine. Haven't noticed any legs moving or shifting
    intex 20x48, sand filter, BBB. had a 30k gallon inground at old house. been around awhile. used to be foster400 here. forgot password and no access to old email so new profile :(
    cfherrman's Avatar
    May 2017
    Hays, Kansas
    1,166
    Hey sorry about the late post here. Last summer I ran my 24' at 38" height due my middle 6 year old daughter so she could touch. I was able to get away with this due I installed main drains in the floor for suction and used the factory suction port as a return. I could not vacuum or skim the surface, it worked fine, I brushed a lot to clean the floor but it was a little dirty.
    This year I'm putting a Hayward skimmer in and filling it full.
    Intex 24' x 52" Filled to 38"
    2 Main Drains, hard lined 1.25" and 1.5" PVC
    1/2 HP Intex Pump 633T w/ 42 lb 13" Sand Filter
    TF-50 and Taylor 2006 Test Kits
    Targus 19" sand filter to be installed and some sort of pump
