Results 1 to 7 of 7
Thread: Hard wired timers
    Hard wired timers
    Does anyone have any experience hard wiring a time in for their pumps? I would really like to automate the process of turning the pump on and off each day.
    16 x 38 inground pool, 20K gal, vinyl liner, 0.75 HP Hayward Superpump (SF 1.0, 115 V), Hayward Pro Serier Top Mount 24" sand filter (300lbs sand) with 62GPM design flow fate and 3.1 sq ft effective filtration area, Kreepy Krawly cleaner
    22,553
    Re: Hard wired timers
    There are tons of folks that have hard wired timers for their pumps. What type of timer do you want to use? You can use mechanical timers or electronic timers. There are also timers that will handle multiple schedules and some that will handle multiple equipment. Tell us what you expect it to do and we can help you spend your money.
    I only have a pump to turn on and off. Mechnical would be fine. I don't think I need multiple schedules. I just want to be able to have the pump run each day without having to check on the pool each day. One feature I would love to have is some sort of override so I can turn the pump off either at the power switch or at the timer, while not losing power to the timer and losing time.
    Take a look at the Intermatic timers like the T101P3 (115 volt) and T104P3 (230 volt).
    22,553
    My recommendations would be the same as Jason's.
    The only caveat to the above timers is if by 'power switch' you mean circuit breaker, then you would have to power the timer motor separately from the contact power in order to do that specifically. There are timers that retain the time when power is lost but they are a lot more expensive and resetting the time on one's listed above is very simple.
    I just meant turning the pump off at the switch. I assumed that the power to the timer would be cut off if I turned off the power to the pump at the outdoor switch. I was assuming the power to the timer would be the same as the power going to the pump, after the switch
    22,553
    Yeah, I figured that's the switch you meant. I just wanted to cover it in case it was a question in the future for someone.
