Results 1 to 8 of 8
Thread: Losing prime everytime we turn off pump....
    Torsie's Avatar
    Apr 2008
    NW Arkansas
    34
    Started a couple of days ago. Everytime we turn off the pump you can hear
    this big "whooshing" (for lack of a better term) noise and all of the water
    goes out of the pump basket. It's like we have to prime the pump when first
    starting up the pool. Takes a long time and then the pump basket will stay
    full and everything operates fine....until evening when we turn the pump off
    again and then "whoosh" the water is gone again.
    Any ideas or what other info I need to give for you guys to help?
    Thanks, Torsie
    NW Arkansas
    17,300 IG Gunite pool approx 16 yrs old (here when we bought the house in 2004)
    1.5 HP pump (rebuilt in '06)
    TA60 Tagelus Sand filter (sand replaced in '05)
    22,537
    Re: Losing prime everytime we turn off pump....
    It sounds like air is getting into the filter and pushing the water out of the pump whenever you shut it off. Can you see air in the pump basket while the pump is running?
    There are a few common places where air usually gets into the system at.
    1. The pump strainer basket is the most common. Take it off and clean and lube the o-ring and sealing surfaces there.
    2. Check the skimmer to see if it's creating a vortex thereby sucking in air. If it is, try raising the water level in the pool
    3. Check the skimmer weir (flapper door) to make sure it's operating freely and not sticking.
    4. The pump drain plug. Remove the plug and clean the threads and t-tape them and thread it back into the drain.
    Temporarly until you find where the air is getting in at you can go out right before you turn the pump off and bleed out any air in the filter with the air bleed valve and see if the pump stays primed.
    May 2011
    lebanon tn
    370
    sounds like an air leak on the discharge side, letting all the water flow back to pool... look for any leaks while pump is running
    darn- I'm the slow typer today! What Bama said...
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
    Aug 2010
    Dallas, TX
    4,052
    Mine was caused by an air leak around the pump skimmer basket and another at the plug/drain at the bottom of the skimmer basket. Once those were fixed, no more losing prime.
    Torsie's Avatar
    Apr 2008
    NW Arkansas
    34
    Thanks for the responses folks. We will check all of these things and hopefully something will
    help and it won't be a big deal.
    NW Arkansas
    Kes's Avatar
    Apr 2010
    Worcester UK
    46
    And mine was caused by a disintegrating multi-port valve gasket. Now it holds for several hours.
    11,000 Imp galls inground hopper 15' x 35', Delifol liner (vinyl), sand filter, Abrisud Classic cover, Palintest 315C test kit
    Torsie's Avatar
    Apr 2008
    NW Arkansas
    34
    Okay folks. Thanks for your replies and we bought a new O Ring for the
    pump basket and so far we are not losing prime. Also, it was leaking some
    each time we turned it off and it no longer does that. Hopefully that takes
    care of our problem.
    Thanks everyone you're the best!!
    NW Arkansas
    ThePoolNinja's Avatar
    Apr 2011
    Southern California
    61
    Simple O-Ring Fix, nice! If you don't already have one, you may want to install a check valve as well. Good luck.
